Thread: Water won't move through filter at near freezing temp
    iam4iam's Avatar
    May 2012
    Johnson City, TN
    228
    Tonight is the first night I've had to turn my pump on to avoid freeze damage. It has only been running about 20 minutes every 3-4 days, since I'm only running it when adding bleach at this point. When I turned it on tonight, the water didn't move and I thought I might have waited too long, because the water didn't move! Finally, after several minutes of near panic, I decided to switch the filter to recirculate and the water is moving fine when bypassing the filter. Is this normal? Should I expect to have to bypass the filter in sub-freezing temps when I'm only running the pump to prevent ice damage? I guess I'll put it back on filter tomorrow during the day to see what happens. It's supposed to be in the upper 50's.
    ~18,000 gal (16x32) vinyl
    Hayward sand filter
    Circupool RJ45 SWG
    Hayward Max-Flo XL SP2305X7 pump (0.75 HP)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Water won't move through filter at near freezing temp
    No, it's not normal, but I'd bet if it was ice that the water flowing on recirculate would have cleared it after a few minutes unless it had been frozen for days.
    30,431
    The problem is not ice.....it's not cold enough in TN yet.
    iam4iam's Avatar
    May 2012
    Johnson City, TN
    228
    Not sure what the problem was. All seemed fine today. Guess I'll have to wait for the next sub-freezing night to see if it happens again. Thanks!
    Hayward sand filter
    Circupool RJ45 SWG
