Thread: new Indoor pool...
    Apr 2012
    Lynchburg, VA
    90
    new Indoor pool...
    A client of mine will be constructing a new indoor pool.
    I wanted to make a suggestion for chlorination...
    What would the thoughts of this board be, salt or liquid chlorine?
    TIA
    PF
    The Most Interesting Pool Man in The World
    I don't always have clients that want to maintain their pool,
    but when I do, I send them to troublefreepool.com!
    38,301
    Re: new Indoor pool...
    I think either would be acceptible options.
    You will just be able to run the CYA level much lower than typically recommended for SWG outside.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Either is fine...salt sytem automates chlorine dosing, so that's a nice plus.
    30,421
    Because the chlorine requirements of an indoor pool are much less than outdoor, I would tend to lean towards manual chlorination. It'll likely be cheaper and fairly simple to manage.
    Do we have any forum members using salt indoors? I can't remember.
    Nov 2011
    Moberly,MO
    1,010
    We have a couple of indoor pools on salt. One has an auto cover with an IC40 and an Intellitouch system. This one works rather well as you can adjust it in 1% increments. We have another one that is a stand alone unit IC20 that the homeowner does not regulate the output and has caused liner damage due to that. Just remeber with a salt system you can use a smaller unit on an indoor pool. I would recommend a UV unit on an indoor pool.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Isaac-1's Avatar
    SW Louisiana
    6,711
    My indoor pool currently uses liquid chlorine, I use a metering pump for convenience, consumption is fairly steady dependant on pool use and temperature and is much lower than an outdoor pool. Always less than quart per day of 5.25% liquid , this means topping off the 15 gallon bulk tank about every 2 - 3 weeks in the active swim season, closer to .2 gallons per day on average for the summer swim season. During the colder non heated (has solar heat to extend season) months when water temperature drops into the 50's consumption drops to almost nothing, maybe .1 gallon per day, probably even less.
    Ike
