Thread: Pump replacement
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    Pump replacement
    I have a Sta-Rite P6RA6G-207L 2HP 230v single-speed pump. My pool is ~12,000 gallons, DE filter, chlorine generator, heater, spa with water feature, booster pump for cleaner.
    Looking to replace with 2-speed pump to save some $ on electricity. Any recommendations??
    Master KomodoKamado griller & beer maker!!
    12,000 gallon in-ground, pebble-tec, SWG pool w/spa
    22,550
    Re: Pump replacement
    I'd suggest just replacing the motor with a 2-speed model if the wet end is in good shape. I assume you need the 2 hp for the spa & water feature so I wouldn't go much smaller.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    https://www.americanbestpoolsupply.com/ ... 129178.htm
    It may require a new mount unless it has the foam spacer.
