Thread: Will these work as a replacement for chlorine tablets?
    mrmiguelrobles's Avatar
    Oct 2012
    Puerto Rico
    20
    I recently saw this at the local grocery store, I've read a little about the BBB method and I was wondering if this toilet bowl cleaners could be a replacement for chlorine tablets. On the attached photo you could see the ingridients as I do not know for a Fact the ones on a chlorine tablet.
    Peanut Shape Fiberglass, Varies 10-14' X 25' long. 3.5' Shallow- 5.5' deep end, about 7000 gals.
    Splapool 1 HP - 75Gpm Pump and 100Sqf Cartridge Filter.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Will these work as a replacement for chlorine tablets?
    I presume you have read the Pool School to learn the problems of using only Trichlor tabs. Chlorinating liquid or bleach has the least side effects since it doesn't increase Cyanuric Acid (CYA) nor Calcium Hardness (CH). The toilet bowl cleaner are essentially bromine tabs somewhat similar to what would be used in a bromine spa though have more chlorine in them then typical bromine tabs. What is it you are trying to do?
    Oct 2012
    Puerto Rico
    20
    Quote Originally Posted by chem geek
    I just saw this ones and based on the little I've read on the BBB method, since I do not know exactly what are the components on a pool chlorine tablet , took a wild guess if this would do the same work... Now I know it doesn't , thanks!
    Mar 2007
    San Rafael, CA USA
    12,082
    Trichlor pucks/tabs have the chemical "Trichloroisocyanuric acid" aka "trichloro-s-triazinetrione" aka "Trichlor". However, if you read about the BBB method in the Pool School you would know that you want to limit your use of Trichlor since it increases Cyanuric Acid (CYA) over time thereby reducing chlorine effectiveness which can then let alage grow. So I still don't understand why you are trying to find a direct substitute for Trichlor. Please read How to Chlorinate Your Pool in the Pool School.
