Thread: New Deck Box installation
    I have one last thing left with my final pool inspection and it seems to be the thing that is causing me the biggest problem. The deck box. Before going into detail about that I'll give you a little back story. As mentioned in my signature I have a 16x32 inground pool, I have a 100 amp panel dedicated to the pool end approx 18ft from pools edge and a 100ft from the house. What I thought was my final electric inspection turned into a small list of things that I have to fix and one thing being the deck box. As you will see in dark picture (sorry just took it and its dark outside), the current outlet box that I'm needing is located on the right of the panel. You can see the pool concrete behind the filter on the top left. I've purchased the correct deck box to install but I'm having troubles understanding how I need to install it so that I can pass my final inspection.
    The deck box has 3 holes in the bottom. The center will be connected to the 1 inch conduit they pool guys installed for the light and based on what i'm reading it states the other two are needing metal conduit. Can anyone help me understand how exactly this needs to be done?
    Thanks in advance.
    __________________________________
    16x32 IG Vinyl Pool : Sand Filter : 1hp single speed Pump
    Electric: 100amp panel box
    Mar 2011
    441
    Re: New Deck Box installation
    Just about every deck box I have seen recently has had plastic pipe in them. Sometimes metal is required for support.
    20X40 30,000 gallon gunite pool
    Thanks. Deck box passed inspection after passing the bonding wire through the little hole in the post in the back of the deck box.
    Thanks again.
