No more Solar Cover
tcat
1,611
Austin, TX
CircuPool Edge-40
Being a new pool owner mid-summer, I decided to buy a solar cover thinking it would keep leaves out of the pool and warm the water some. Cut to fit and installed 3 or 4 weeks ago. Now that leaves and acorns have been falling, I decided it's MUCH easier to keep the pool clean without the cover. Removed the cover today, did some net scooping, let the Kreepy Krawly run a couple hours, and pool looks so much better. May put it back on in the spring to see if it actually warms the water at all, but it really just makes for a lot more work!
I think some solar panels, and Liquidator will probably be a much better investment.
From what I have read on this board, a solar cover mainly helps by preventing evaporation - so nightly use is more important that daytime use. Off when the sun is hitting the pool, on when it isn't - is supposedly the most efficient. It allows the sunlight to warm the water and then prevents the losses due to evaporation after the sun is no longer on the water. You can leave it on during the sunlight but it is supposedly less efficient when you do this.
It all depends on the color. A clear cover allows the sun to heat through the cover, A dark cover absorbs the heat and a silver cover reflects the heat. So with a silver cover it's especially important to remove the cover during the day.
Somewhere I saw a study where they showed heat gain was best with no cover, second best with a clear cover etc.
Sent via Tapatalk...
Link would be helpful
I'd love to see something definitive. I never know whether to have my cover on or off, depending on whether the sun's shining or not, how the air temp compares to the water temp, how much wind there is... there are so many variables. Should I remove my blue cover when the sun is shining, but keep it on if it's cloudy? What if it's sunny but there's lots of wind, or the air temp is lower than the water temp? I mostly just leave it on; it's easier that way. :)
I think someone should "invent/manufacture" bubble wrap with a large round bubble (like 6" dia) formed in the shape of several magnifying glasses (lens shaped), that magnify the sun to a point (you know like the fires we started when we were kids)... now THAT should heat the pool up! Or maybe a large lens mounted on an arm over the pool with the focal point on the pool surface... with motorized gimbal system that followed the sun.
My pool is much cleaner and easier to maintain now that I put my cover in the garage! And just as cold.
The details of the studies that back this US Government claim are not available to me (yet) but it's consistent with what I have read in a number of places: http://energy.gov/energysaver/articles/ ... ool-covers
No cover is best heat gain from solar radiation; clear is next best; opaque is worst.
There is nothing in this that says what happens if there is dry wind and the air temp is lower than the water temp - in that case I would suspect a clear cover would outperform no cover since the loss vs. no cover in heating is 5-15% and I would expect evaporative cooling impact to be > than 15% of the original heat gain.
Another document source:
http://www.nrel.gov/docs/fy00osti/28038.pdf
This says the same basic thing but goes on to say that using one during the day may help and says that the drier and cooler the air the more this may apply. It also is pretty clear that the cover should be on at night no matter what (when not swimming) if you are trying to retain heat.
WOW! $250 to heat an outdoor pool in Dallas? I guess my normal temp is 82 and if you're only heating to 82, I guess that makes "some" sense. But really amazing numbers in that chart. Not to logical in my mind.
This doesn't directly address the studies but does have some really cool software for calculating your heat losses and determining the cost to maintain your pool. I was shocked by the cost factor of heating an indoor pool vs. an outdoor one.
http://www.rlmartin.com/rspec/software.htm
We lived in Killeen, TX for 6 years so we're pretty familiar with the weather in Austin (nice city and TX is a great state to live in.) Our weather in Savannah is similar but much more humid so I'd expect evaporation to be greater in Austin and a cover will help with heat loss and extra chemical usage due to evaporation loss. The "steam" you see coming off of the water at night is your heat leaving the pool (or any body of water for that matter.)
We have a clear solar cover and solar heater and here's what we've found works for us: We use ours from about late Feb-early March untill late May, then no cover typically until late Sept. Solar heat use is typically from last freeze (late Feb early Mar) until early June, then again from mid Sep until late Nov. We generally maintain a pretty warm pool through the summer (84-89) depending on weather conditions, without using the cover at all. The heater is on a thermostat so we really don't shut it off in the summer, we just set a temp of about 86 and it keeps it there as needed. I've noticed that it does not run much from mid June - Aug though. The cover basically minimizes heat loss over night and if you get a cold spell. As for adding heat, the cover is a layer of insulation so it would seem that heat transfer would actually be greater (given direct sunlight and water temp < air temp) with the cover removed. The pool definitely looks better without the cover which is why we remove it once we are done swimming for the season. (Nov-Feb). As for cleaning, I think it is personal preference on that. We have a roller and when using the cover it is pretty easy to skim everything off right after we roll up the cover as all of the trash ends up falling off under the roller. Hope this helps you in your choices.
Try this calculator to get more control over the variables you are setting. Be careful not to hit calculate before you setup the schedule - I did and nearly choked on the $27K bill for heating the pool 100% of the time 365 days a year!
http://www.energyexperts.org/Calculator ... lator.aspx
