If i might add: while i'm on my 2nd day shocking, i vacuum daily, empty and clean both skimmer & pump baskets, check pressure on a daily basis. i dont want the chlorine to be working overtime on garbage sitting in the baskets or on the pool floor.
i noticed however, the skimmer does pick up a lot of dust ( floating on the surface), bugs right into the filter n so on. Makes me wonder, even if the pressure doesn't rise by much, doesn't all that garbage slowly piling up in the filter contribute to CC"s? or cloudy water?
I experimented a little while ago by doing daily mini short backwash, just to dump whatever accumulated during the day out of the filter. With every backwash, the site glass was always a thick yellow brownish muck ( everyday). Is this the muck the result from all the dust debris getting pulled in daily and the chlorine trying to break it all down? Wouldn't it be wiser to remove the muck all together to aid the CL? Despite the fact that a backwash should only be done with an 8 to 10 psi diff.
Please note: when the daily muck being backwashed out a there, my water was always clear. I though then it was obvious the muck had to be from all the dust n stuff being pulled in by the skimmer - what else could it be if no swimmers are around?
