Results 1 to 13 of 13
Thread: PVC, PVC Schedule 40 or Flex?
    Jun 2010
    Toronto, ON. Canada
    230
    Finalizing a pool build and the PB is stating that he uses PVC (black) and flex for all the large turns.
    What re your thoughts?
    I have read that he is should be using schedule 40. He claims that sch 40 is too ridgid...
    16'x34' Inground Vinyl Pool. 65,500L. Hayward S244T2 24 Sand Filter. Hayward 1hp Super Pump. Raypak PR266 EN 266,000 btu,. AquaRite SWCG. Aqualamp LED 2 w/ remote
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: PVC, PVC Schedule 40 or Flex?
    Sch 40 is the standard, because it is the strongest. It is tried and true, and lasts for decades if installed correctly! Flex is convenient for the builder, but many times causes problems down the road.
    Never seen black PVC, at least not around here...black pipe is either ABS (rigid) or poly (flexible).
    Jun 2010
    Toronto, ON. Canada
    230
    Quote Originally Posted by Melt In The Sun
    Thanks. PB was probably referring to poly...
    So if he uses poly and flex is that ok?
    i understand why he chooses not to use sch 40. it might have to do with the harsh temperatures you guys have in toronto.
    pool size 15X30 Filters:Cartridge Aboveground Plaster,Pentair Minimax NT Low NOx Series Heater
    if it helps, i in my years of pool service and my dads 38 years of pool building experience, he has never seen an issue with black poly pipe.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I'd also opt for rigid pvc or poly. Flex is just more convenient for the builder but often only used in the tight radius for spa plumbing and encased in gunite, otherwise I would minimize flex pvc use.
    Oct 2009
    3,899
    Didn't notice your location at first...poly is used a lot more in cold areas because it has a little bit of give to it.
    Dec 2009
    Central Massachusetts
    2,690
    I would use the black poly. Up north thats the prefered pipe for ground that freezes deeper. Even if sme water is left in the pipe, it will expand enough to not burst. Shifting ground wont hurt it either. PVC will shatter to easily. Thats why pool builders and irrigation guys in cold climates use black poly.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2010
    Toronto, ON. Canada
    230
    Thanks! So a combination of poly and flex is ok for Toronto?
    Oct 2009
    3,899
    I still say nix the flex. It just isn't as tough as the poly. With poly you want as few buried joints as possible, so transitioning between different kinds of pipe would likely be problematic.
    Dec 2009
    2,690
    +1 poly all the way. No joints.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Everything has it's pros and cons.
    poly is durable but can't be glued so the mechanical joints could leak, but the pipe can be curved when warm to achieve a large radius curve.
    PVC is very common, rigid, glued joints are good but it can shatter if something happens since it's brittle compared to poly.
    Flex PVC, glued joints and is the most flexible which will lessen the need for joints. Not as tough as poly or PVC for the most part. (But if you are going to smash each one with a hammer side by side, flex will win. A standard razor blade can cut flex but not poly or pvc)
    Nothing is perfect, it has a lot to do with installation. I personally use all 3 but most often use flex, then some pvc, and then maybe some black on occasion. I've been noticing though that flex above ground does tend to get UV damage the quickest of all three. It can get brown and bubbly. This also might not be the clearest determination though as I've had PVC pipe and black poly pipe look normal and then shatter when attempting to cut them, the pipe had been sitting in the sun for many years.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Mar 2012
    Cincinnati
    33
    Go with flex, 100' rolls glue fitting at the wall and at the filter been using flex since 1988 because in 1987 when we used poly pipe every roll we got that year was defective and had to replace all lines under warranty "NOT FUN" Only problem with flex and I have only seen it one time is termites and I have used hundreds of rolls of flex pipe in the past twenty five years, make sure to use cleaner and glue designed for flex pipe (Pool Tite) and you should have no problems Just My Opinion
