Thread: Pentair Rainbow Auto Feeder Model 320 Question
    Hello,
    The home i bought has a Pentair 320 Chlorine Generator which i don't plan to use. Is there anything wrong with not putting tabs in it and leaving it installed or is there a way to just disable it? Unit was used by previous owner (10yrs) and has lots of paste buildup inside canister so it probably doesn't work that well anyways. I thought about removing it all together but at this time i don't want to cut pipe for removal. Thanks!
    sand filter
    18K pool
    gunite
    inground
    use liq chlorine
    pentair model:
    http://www.allpartspoolandspa.com/store ... 2-196-W007
    38,251
    Re: Pentair Rainbow Auto Feeder Model 320 Question
    You can just leave it empty for now. May want to clean the gunk out though.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Clean it up so you can use it for vacations.
    Jun 2007
    New Jersey
    653
    Mine is stored in the basement in case I ever need it. I capped the inlet and plugged the outlet (or vice versa) and left the diverter in place so I can reinstall it in minutes if I want to. Been that way for five years.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
