Thread: Negative/Infinity Edge Spa
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    Since we are having a spa built into a shallow landing/beach area of the new pool the contractor has given us an option to have a negative/infinity edge effect on the spa at no charge. What are the negatives and positives of a negative edge spa? Can you still sit on the spa edge if it has a negative edge? The spa elevation is only about 3" above the pool water level and about 3/4 circle inside the water (Pool water is surrounding the spa by about 75% of the spa ledge area). The Contractor said that he would only put a 1" of rise in the 14" spa ledge. The pool sits between our house and the edge of a lake.
    21,500 gal sport pool, 8' spa, beach, 400k btu LP heater, Pentair IC60 SWG & #300 Tablet Feeder, 60 sqft DE filter, Paramount in-floor PoolValet 3 cleaners, Debris Canister, Polaris 360, Pentair VFD 3hp pump, IntelliPh, Geysers & Turbo Twister Slide w/1 hp pump, Color LED Pool & Spa lights, E-Z Touch8 control system, Wireless controller. Test Kits:TF-100, Taylor K-1004, CYA K-1720, Phosphate K-1106, Salt Water K-1766, Hach CN-39WR.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Negative/Infinity Edge Spa
    It just looks nice! It's up to you really...I think generally having a negative edge would make it easier to splash water in and out of the spa, but that may not be the case with your design.
    Jul 2012
    CA
    240
    A friend has a negative edge, says he pours m.acid in all the time due to aeration. Also if you have a swg, i think wall would get fadded qucker.
    25k I/G ecostar ccplus Polaris plaster
    Mar 2011
    Scottsdale, AZ
    406
    Say what????????
    And I am not talking about the misspellings.
    How does a SWG cause fading?
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    My thinking is that I won't have to worry too much about water from the pool entering/splashing into the hot tub because the spa is several inches above the pool water level. The hot water displaced upon entering the spa will spill over into the pool and be lost. My initial thought is that the spa heater will not be on except prior to wanting to use the spa and the spa will be isolated from the pool by valving while in use. Under normal non spa usage the water will be also entering the spa and overflowing into the pool as the in floor nozzles cycle thru the cleaning cycle. When the spa is in use the spa suction will be used and the returns will be the spa jets. When the spa is not in use the pool suctions and cleaning nozzles will be used. The spa is just another zone in the paramount cleaning cycle under normal circumstances. We decided to go ahead with the spa negative edge. If I had it to do over again I would have the water completely surround the spa 100% and do the negative edge so the spa would be practically invisible except for the outline during non use. We are also going with a black bottom pebble pool with dark blue tile line, dark blue tile spa, and dark blue tile landing/beach/steps area.
    mnittler's Avatar
    Sep 2012
    South Texas
    58
    We went ahead with the negative edge spa. I am actually standing on the spa negative edge ledge which is 1" above pool level.
