Thread: skimmer float valve - installation tips
    Jun 2007
    SF Bay Area
    441
    I am finally getting around to doing a partial drain and refill to correct my inherited high CYA (at least 150 ppm) problem.
    I homebuilt a filter drain-to-hose adapter, so a small slipstream from the main pump flow is being sent to waste. My problem is that once the pool level went below the skimmer level, I started getting quite a few air bubbles. I suspected that the Swimquip (Sta-rite, now Pentair) float valve assembly might be at fault. So I went down to my trusted (?!?) local Leslie's and picked up a brand new float valve assembly (08650-0079) that also came with a new o-ring.
    After getting the new float valve, I see that the old existing float valve was completely missing the "trimmer plate" that apparently adjusts the percentage of skimmer flow versus main drain flow. With a missing "trimmer plate" I see that all of my flow was coming from the skimmer and none was coming from the main drain. Oh, and the 6-inch diameter o-ring was completely missing, which would certainly help explain the suction air leak that I have been fighting.
    My main concern for installation is how to not lose the 6-inch diameter, 1/8-inch thick 0-ring down the skimmer suction line. I am thinking about installing this o-ring with the Leslie's lubricant, which starts out as fairly sticky and only gets more so with age. Is this adequate so that I will not lost this o-ring, or should I be considering "gluing" this o-ring in place with something like gasket glue?
    Thanks for any ideas and comments.
    Titanium
    24,000 gallon inground freeform pool/spa circa 1983 (113 ft perimeter, 625 sq ft) with 350 gallon attached spill-over spa
    2007 2 HP, three-phase Hayward TriStar pump which is powered by an Ikeric VS-200 variable speed drive system
    1983 Laars XE Pool/Spa Heater Type ES 400,000 BTU, 1998 Hayward Super Star-Clear C-4000 cartridge filter (400 sq ft, 4 separate cartridges)
    1998 Polaris 380 pressure-side cleaner w/ 3/4 HP booster pump
    One skimmer :( and one PoolSkim :), One Supervision Galaxy LED pool lamp, Second story solar panels
    Hayward/GoldLine AquaLogic PS4 (replaced 1983 vintage dual circuit Intermatic timer)
    Jun 2007
    SF Bay Area
    441
    I went ahead and installed the 6-inch diameter o-ring into the skimmer o-ring slot with just the o-ring lube from Leslie's. So far so good in that it is staying in place. Even better is that the suction side air leak that I have been fighting during this partial pool drain has gone away.
    Side note: This partial drain and refill business is a real pain. I am only getting 1 inch of water removed from the pool every 60-90 minutes, so this whole process seems like it is taking forever.
    Titanium
