Results 1 to 7 of 7
Thread: need help urgent!! white thing coming out
    Sorry my english is not too good. but if anyone can help me.we are having problem with our 2 magnapools. Please see the attached file. its mineral pool. The reading of CL and PH are good. First we set the machine 100% but after white thing come out we reduced to 50% its ok no white thing coming off.
    please help. we asked every experts in Thailand but no one can help us
    thank you
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: need help urgent!! white thing coming out
    Your system is similar to a Salt Water Chlorine Generator, and what you are seeing is probably hydrogen bubbles in the water generated by the system.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Hi pokalook,
    Welcome to TFP!
    It could also be air bubbles, which would mean you have a leak somewhere.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Thank you very much for helping us! so if its hydrogen bubbles from the system. that's mean we don't have to do anything about it?? There's no leak(not that we can see)
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I am curious as to whether it does this continually while running, or only at start up for a short while. After which it stops outputting those bubbles?
    What happens if you shut the chlorinator completely off, but still run the pump and filter. Do bubbles still come out of the return jets?
    Have you checked the chlorinator cell to make sure it's clean and free of calcium buildup scale or any debris that might have worked its way in there?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by pokalook
    Can you elaborate as good can vary quite considerably? Please tell us your chemistry levels. FC, CC, TA, PH, CH and CYA.
    It may be your CH, PH and TA levels that a making the issue so pronounced.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Picture?
    Sent via Tapatalk...
