Results 1 to 10 of 10
Thread: Optimal pH for closing?
    Jan 2010
    Northern Virginia
    282
    I have a gunite pool with a SWG that's just gone through its second season. When it was opened in the spring I had a massive scale problem. I got rid of it all with a couple of no-drain acid washes but I want to ensure I don't have a repeat performance.
    What pH should I shoot for before they turn off the pump and close it down? 7.2 or should I go lower?
    Latest numbers:
    FC 5
    CC 0
    pH 7.3
    TA 80 (working on lowering it a bit)
    CH 550
    CYA 85
    Thanks!
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Optimal pH for closing?
    You do not want to go below 7.2 because you water can be carosive and that is hard on the plaster and equipment
    Jan 2010
    Northern Virginia
    282
    Thanks!
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Bart
    Latest numbers:
    FC 5
    CC 0
    pH 7.3
    CH 550
    CYA 85
    I plugged those numbers into the Poolcalculator and it looks like you would be OK at 7.3; both result in slightly negative CSI index values that aren't that aggressive until the water gets to about 40 degrees. Since you have had scaling problems I assume you want a negative CSI - however since you do get to -0.61 at 40 degrees with a 7.2 pH that might be more aggressive than you want. However I'm not very experienced in this area so I would ask around a bit more before making up my mind.
    Mar 2007
    San Rafael, CA USA
    12,082
    As the water cools down, the pH will rise even if there is no carbon dioxide outgassing. From 85F to 45F, if there is 50 ppm CYA in the water then the pH goes from 7.5 to 7.7 while with no CYA it goes from 7.5 to 7.8. So the saturation index tends not to move very much with temperature because of this effect.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by chem geek
    Sticky this info! That's very helpful to know.
    Sent via Tapatalk...
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by UnderWaterVanya
    Indeed it is, especially since it seems pool calc doesn't compensate for this.
    Correct?
    I can do just what I'm sure UWV did and that's to enter all your test results, then enter a temp. As you change that temp by entering different values, you notice the CSI numbers fluctuate. Hrrrmmmm
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Jun 2012
    Mint Hill, NC
    2,589
    [quote=y_not]
    Quote Originally Posted by "chem geek":17jyzexy
    Correct?
    I can do just what I'm sure UWV did and that's to enter all your test results, then enter a temp. As you change that temp by entering different values, you notice the CSI numbers fluctuate. Hrrrmmmm[/quote:17jyzexy]
    If you think about it, the calculator did what it should - it told you that at a particular temp with that pH the CSI would be "x". What it does not do is give you an option to say that temps are falling what happens...in which case pH should rise and help the index stay similar to before.
    It is obvious now that Richard has said it. As I recall gas solubility in water goes down as temps fall.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Aaah, you are correct indeed. I missed the part where he said that pH goes up as the temp goes down. I thought it all remained constant because of a temperature offset.. I was wondering why nothing else would change.... N/M. LOL
    BRAIN PPPPBBBTTTT!!
    So if we set it at X temp and CSI is where we want her. Then she stays the same as the temp falls throughout the winter and into the nights. Yeah?
    What about when temp goes up? What happens then?
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by y_not
    The CSI doesn't stay exactly the same. As the temperature goes down, the CSI goes down a little, but less than if the pH didn't change. When the temperature goes up, the pH drops exactly as much as it rose when the temperature went down and the CSI goes up a little back to where it started. The reason for the pH change is a change in the equilibrium constant of water (in equilibrium with hydrogen, really hydronium, and hydroxyl ions) as a function of temperature.
    Since the temperature changes are slow and since there is usually carbon dioxide outgassing going on, one may not notice this effect. I do notice it in my pool since I have an automatic electric cover on the pool so when not in use it doesn't get much outgassing and the temperature can drop a lot in a week after I stop using gas at the end of the season for heating it. Same thing with spring startup. So I notice this effect, but most people wouldn't. During the months of winter, however, there tends to be a slow pH rise in my pool that I need to adjust for now and then, but I keep the pH on the higher side when the water is cold as one way to keep the CSI more in balance.
