Thread: Alkalinity test in the T100
    Oct 2012
    Small Town Indiana
    29
    Any thoughts about color change? Typically it is blue and then you add drops of #9 until it turns red (or in high chlorine it turns yellow). Any thoughts if it just turns a different color or blue? I wasn't sure if I "overshot" the red? Has anyone seen this before. I tested it yesterday and that didn't happen. Just a curiosity question.
    18,000 Gallons, 16 X 32, Sand Filter, IG, Vinyl Liner, SWCG, Built 2011, Opened April 2012, TF-100, speed stir,
    38,284
    Re: Alkalinity test in the T100
    You can find more detailed info about all the tests here:
    extended-test-kit-directions-t25081.html#p206395
    Mar 2007
    San Rafael, CA USA
    12,082
    It usually starts of green and goes to red after you've added enough R-0009 titrant. If it starts off blue then that usually indicates a high chlorine level in which case it will go to yellow. You can add more R-0007 thiosulfate drops to reduce the chlorine at the start of the test so that you have a normal green to red transition.
