Thread: Left over trichlor pucks after pool closing
    Aug 2011
    Central New Jersey
    20
    What should I do with half-dissolved left-over trichlor pucks after I closed the pool for the winter?
    Is there any way to safely dispose of them? Should I pack them away and use them next year?
    Thanks!
    Damian
    29k gal. In-Ground Plaster Pool (Freeform), Hayward Pro Grid DE4820 (48 sq ft), Hayward SuperPump II (1 hp), In-Line CMP chlorinator
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Left over trichlor pucks after pool closing
    Let them dry out and put them in a plastic bag until next year.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Aug 2011
    Central New Jersey
    20
    Do you think I could just let them dry and put them back in the bucket with the unused pucks?
    Damian
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by DPawlu
    Yes, but you should still put them in a plastic bag.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Qwaxalot
    Is this because of residual moisture being a concern?
    If it is - the addition of small silica packets inside the bag will help avoid any moisture from causing problems inside the bag.
