Results 1 to 8 of 8
Thread: Drain below the skimmer or not?
    Apr 2012
    South Dakota
    87
    I had my inground pool closed a few weeks ago and the local pool guy said that they don't drain the pool below the skimmer. Should I be doing this? I questioned because when I bought the house early this year the water had been drained below the skimmer when it had been closed the past winter.
    Thank you
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    22,537
    Re: Drain below the skimmer or not?
    A good number of people drain below the skimmer and that's partially to protect any waterline tile from freezing water. Since you don't have tile (I'm assuming ) you could use a gizmo, etc to protect the skimmer from ice expansion. Maybe that's what they do.
    Oct 2012
    209
    Do you have a mesh or solid cover?
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Apr 2012
    South Dakota
    87
    I have an Aqua Genie and they just take the return plate off and put on a plate that blocks the opening completely.
    Vinyl liner
    Taylor K-2006
    Apr 2012
    South Dakota
    87
    I have a solid cover.
    Vinyl liner
    Taylor K-2006
    Oct 2012
    209
    Then ....unless you have tile (as stated earlier), or you need a drain down for chemical reasons......there is no need to drop it down that low. As long as the company who closed your pool did a good job of blowing the lines and sealing them up with gizzmos....you should be fine.
    Oct 2012
    209
    Oh...i missed the aqua genie post....no need for gizzmos unless water can get in there.
    Apr 2012
    South Dakota
    87
    Thanks for the advise. I will leave it how it is now.
    Vinyl liner
    Taylor K-2006
