Thread: Why leave the system 'open'
    This is my first year closing our pool. I've removed all the plugs, drained the various parts, blown out the lines, installed plus in the returns, etc... What I'm trying to figure out, however, is why I would wait until spring to reconnect the pipes. I had a pro do it last year (we were brand new to it), and he left everything open like this, but this seems as though it would invite the possibility of water, bugs, worms, even small animals getting into the system.
    So, what is the reason for leaving the pipes open for the winter?
    Pool details:
    18x36 Vinyl In-Ground pool
    25,000-30,000 gallons (estimate, will know more when I can get in and get an average depth)
    DE filter
    Pump info unknown - I'll get that soon!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Why leave the system 'open'
    We don't close here, but from what I've read on the forum, that is unusual. I don't think there would be any harm in putting some plugs in.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by mickeyfan0805
    A picture might help. It's normal (as I understand it) to leave out the drain plugs - I assume this is to ensure that if any water makes it in - it can get out. I'm not sure where your "pipes" are open. The advice I was given was to take the drain plugs from filter and pump and stick them in my pump basket. Some type of anti-sieze compound was recommended for the threads of the plugs and the holes but other than that - nothing else.
