Results 1 to 12 of 12
Thread: Obtaining Borate drop test reagents
    Hi -
    The web page for Piscines Apollo indicates they won't ship their borate test to the US. I know the lamotte test strip could be used, but I'd like to use a drop based version if possible. It seems like it could be replicated with mannitol and Bromthymol blue. Does anyone have a suggestion for where to obtain these reagents in the USA? Do they have specific concentrations? Is the amount of mannitol critical (spoon size)?
    Central MA Area
    24K kidney
    salt, DE
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Obtaining Borate drop test reagents
    Taylor has a test kit http://www.taylortechnologies.com/produ ... KitID=2583
    The numbering is different, but they do sell two different reagent refills, also.
    Mar 2007
    San Rafael, CA USA
    12,082
    S-0009 is Bromothymol blue indicator dye while S-0010 is powdered mannitol. Neither are listed as hazardous materials so I don't know what restrictions they are referring to, but they do say here the following:
    **Because of US postal restrictions, we are no longer able to ship this product to the USA**
    I've written to them about it so we'll see what they say.
    Thanks for the quick replies - didn't know about the Taylor test. The instructions aren't online, so I don't know how easy it is to perform, relatively.
    I'm also curious about the postal reg issue, thanks for inquiring.
    I like the idea of reusing k-200x reagents for economy.
    Central MA Area
    24K kidney
    salt, DE
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Richard320
    That's a kit for a colorimeter. The Taylor K-1541 is the drop-based test kit but it is very expensive and too sensitive for what is needed to measure to within 10 ppm. The Taylor test measures within 0.2 or 0.5 ppm so would take a lot of reagent for testing 50 ppm (the instructions only go up to 5-15 ppm).
    I got a response from Apollo Pools and apparently someone told them they couldn't ship liquids via USPS, but that isn't true. I've sent them the requirements from USPS. For their small non-hazardous non-flammable < 4 fluid ounce liquid volumes it just requires screw-top bottles which they are using and an exterior label of "Fragile:Liquid" and identifying the liquid contents. We'll see what they say. They only stopped shipping to the U.S. a couple of months ago after someone warned them not to send liquids via USPS.
    Montreal Canada
    326
    Yes I have removed the restrictions from the site - thanks for clearing that up Richard.
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Since we are on the topic of the borate drop test, I cannot get the sample to turn yellow after adding S-009 reagent. I follow the instructions but the addition of S-009 doesn't cause the sample to turn yellow. That said, I can continue on following the instructions and everything else works fine, sample turns yellow with the powder, and I get the expected result. But do we have any ideas why I don't get yellow early on as the instructions indicate I should?
    Thanks.
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    I got the kit and it was useful - I had thought using "capfuls" of gentle spa was inaccurate, and retrospectively, indeed it was. I will use a scale going forward. I am happy with the test kit. On a slightly related note, you can add me to the list of folks who saw a non trivial pH rise after adding Gentle Spa.
    HofstraJet - Sorry, I don't know the answer as to why your test doesn't turn yellow until you add the powder.
    Central MA Area
    24K kidney
    salt, DE
    Cypress, TX
    37
    It looks like this kit is not available on the website anymore. Anyone know what the deal is?
    Steve
    25,000 gallon saltwater in-ground pool with in-floor cleaners. Medium lagoon plaster. Jandy pump and heater and Glacier Pool chiller. Use iRobot Verro pool cleaner.
    Montreal Canada
    326
    Liability insurance.
    We're working on it.
    Cypress, TX
    37
    Quote Originally Posted by CaOCl2
    Wow, thanks for the quick response. I hope you guys get this resolved. It looks like a great kit.
    Steve
    Jun 2014
    miami,FL
    1
    For Future Info: Amazon lists (as of 6/14) both bromothymol blue and mannitol powder in small pkgs for about $10 each.
