Thread: Suction Pool Vac recommendations
    Nov 2012
    Treasure Coast FL
    12
    Hi All- i am new to this site; have been a pool owner on So.FL for 9+ years. I havee learned alot on my own and love my pool, use it often. One problem i have is I travel OFTEN! almost weekly, so i have to rely on my auto vac to keep it up, but in all fairness I am in a screened enclosure and it doesn't get too bad and never more than the occasional leaf from a potted plant.
    I have great water and it has been a low maintenance pleasure ll these years.
    I inherited from previous owner a baracuda ALPHA- loved it and it worked well with a annual diaphragm replacement and towards the end everything else! that finally went kaput and I bought for 500 dollars a baracuda X7 quattro- which is garbage. It totally broke on me three weeks ago, the "engine" was in pieces. I was highly satisifed with the alpha but the X7 was a disappointment from day 1, i am glad it died.
    Now I am looking at the baracuda G2 as it is basically the Alpha- and just discovered the Poolverngnuegen "The Pool Cleaner". They are basically 100 dollars apart with the pool cleaner being more pricey.
    What i am hoping is to make the best decision so am seaking your opinions if you have either or both. I am not price drive, if the pool cleaner is better the economy will be better in the long haul. I run my pool with a solar heater and swim whenever it is in the 80's (water temp) which is close to ten months a year and as i said, mostly just pollen and a little dirt and such, nothiing big or hard to suck up. Thanks! I have been reading a lot on this site since i discovered it yesterday while researching my vac purchase, wish i knew about it a decade ago when we bought this house!
    10,000 gall. inground kidney shaped Gunite w/ Pentair Intelliflo VS + Haryward T3 SWG, 100SF cartridge.
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    Re: Suction Pool Vac recommendations
    Both cleaners you mentioned are good cleaners but the g2 has less moving parts so there is less to break down. The pool cleaner works well but has a lot of gears and that is more that can break
    Nov 2012
    Treasure Coast FL
    12
    Ordered the 2 wheel model "The Pool Cleaner"- we'll see how it does after a 2 or 3 months.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Please post back...we can never have too many reviews of cleaners!
    fofa's Avatar
    Sep 2008
    Houston, TX
    75
    I have the 4 wheel version of "the pool cleaner" (TPC). I have the Quatro Pro right now and am not a fan of it in the least.
    My TPC worked OK for many years. It is just expensive to replace the tires. It was running me $60-80 (depending what I could find online) to replace them each year. Also the turbine was replaced twice. Never had any issues with the gears. It just didn't cover my pool as well as my old Navigator Ultra did, but it did pick up leaves and acorns without choking mostly. The navigator would die on a blade of grass or pine needle.
    The X7 dies after going about 2 hours. Biggest most expensive POS I have experienced.
    30,000 Gallons, Hayward C5030 cartridge filter, IG, Plaster, SWG
    Nov 2012
    Treasure Coast FL
    12
    Yes, the Quattro is without a doubt garbage. I just returned home from my trip and the cleaner arrived. I am going to wait till tomorrow to set it up, will post my feedback as i use it.
