Thread: Mystery Overnight Pool Drain!
    Bobbystone
    Guest
    I just went down to the pool to dip some leaves out and lo and behold the water has mysteriously dropped 6" over night! I looked around everywhere and saw only minor dampness, no great puddles! Then I dropped some food coloring around most of the fixtures I could get too, and found no great suck. Any thoughts? This is a real mystery!
    30,431
    Re: Mystery Overnight Pool Drain!
    Do you have a multiport valve? Is it set on "filter"?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Do you have a hard plumbed backwash line where water can be drained without seeing water around the pool.
    Sent via Tapatalk...
