Liner install question - gaskets
pcn
Sep 30, 2012
4
Hello, I am preparing to install a liner in our in ground pool and need some advice on gasket installation. Specifically, how do I secure the gaskets on the wall for the return fittings and the gaskets for the main drains? Is there a specific type of glue I should use to hold them in place while I install the liner? Thanks for your advice!
Thanks Kevin, I will see if I can find some Pool Tak around here. The main drains are brand new since I had to replace/replumb the old one. I saw where duct tape was used on the light gasket and the pool step gaskets but didn't think that would work on the drains. I can just see them slipping under the weight of the liner and getting off center, so I hope the Pool Tak is pretty sticky stuff. Thanks again!
