Results 1 to 9 of 9
Thread: pH won't come down and test kit won't give accurate readings
    FC - 1ppm
    CC - 1ppm
    pH - 8 plus
    TA - ?????(using taylor kit and reading is turning yellow, instead of pink, after about 15 drops
    CH - 100ppm
    This is a commercial pool used for swim lessons and it is tested several times a day when we are open, but we are closed for 2.5 days a week and when I returned after the weekend the pH was starting to test high, and a day later it was off the charts.
    The readings have been like this for 4 days. I have brand new reagents and I know they are working absolutely fine because I have another pool in the same building that I'm receiving stellar readings on.
    The water has been crystal clear the entire time.
    HELP!
    15,000 Gallons
    Sand Filter
    IG and indoors
    7.5hp 345GPM
    Built in 2009
    MIOX SWCG and Hanovia UV
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: pH won't come down and test kit won't give accurate read
    Several things are going on here:
    1) CC is too high, FC too low. I suspect a testing error because..
    2) TA test goes blue to yellow instead of green to pink when FC is high
    3) If pH is above the upper limit of the test, it may very well be 9 (or better), in which case the pool calculator is not going to give you the proper dose of acid.
    Solution: keep adding acid until pH comes down. With high TA and a SWG, pH will climb, and climb fast.
    Also recheck that FC and raise it to eliminate the CC.
    Oct 2012
    209
    Are you sure the chlorine reading is right? I've encountered pools where the chlorine is so high it bleaches the endpoint colors in a test. This would result in a "low" chlorine reading, a very purple ph reading, and a yellow reading for TA. Add an extra drop of thiosulphate to your TA test (at the appropriate time) to counteract the chlorine. Also you might not want anyone in the pool if this is the case.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
    Oct 2012
    209
    Also I would lower the chlorine before adjusting the ph....just in case....
    I retested my CC and diluted it getting a reading of around 11 or 12. Then have slowly added acid and the pH has dropped, also shut off my auto-feed for my Chl for a bit so as to not over feed. Thanks a lot, I had been adding acid but I suppose it wasn't constant enough. Thanks for the help
    15,000 Gallons
    Sand Filter
    IG and indoors
    7.5hp 345GPM
    Built in 2009
    PJ - I've had the pool closed, that's the nice thing about having two.
    15,000 Gallons
    Sand Filter
    IG and indoors
    7.5hp 345GPM
    Built in 2009
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by Turtles in AZ
    Combined Chloramines that high? WOW!!!
    That would mean this is an indoor pool, right?
    What did you end up with for FC on this last re-test?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Whoops! That CC was supposed to be FC at 11 or 12. My CC is usually 0 or 0.1
    15,000 Gallons
    Sand Filter
    IG and indoors
    7.5hp 345GPM
    Built in 2009
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    So what are the right numbers? Also what specific test did you use to measure FC/CC?
    Sent via Tapatalk...
