Thread: Solar Cover Reel HELP!!
    Jul 2011
    Southern California
    15
    I've searched forums looking for an answer but couldn't find one. Will a reel work with this shape of pool? I'm guessing I would get one that fits the widest section which is 15ft? We had one cover and totally trashed it dragging it along the brick. I've been looking at reels and there are so many to choose from. The stainless steel one with wheels on one side looks best for the price. Please any suggestions are welcome. Thanks
    15k gallon, gunite, quartz
    Re: Solar Cover Reel HELP!!
    if you can get one with casters it keep it from getting trashed. I personally have built reels for all 6 of my company's pools out of SCH 80 PVC for the stands and then use a 3" aluminum tube for the reel it self and then attach SCH 80 PVC couplings using stainless steel bolts to attach them. A small platform could then be built with casters to set the stands on. The great thing about them is that you can fix them if they break, and the ones I've built are used multiple time each day for the last 2 years and I haven't had to make a single repair.
    15,000 Gallons
    Sand Filter
    IG and indoors
    7.5hp 345GPM
    Built in 2009
    MIOX SWCG and Hanovia UV
    Oct 2012
    91
    I inherited a Rocky's Eazy-Roller with my pool, and it had set in the hot Florida sun for I don't know how long. One caster was rusted through and broke off, so I bought a new set of four at Home Depot. I disassembled it, cleaned the bushings, and cleaned up the rest, and it's working great. There's not much to go wrong.
    14,500 gallons, Clean and Clear 150 cartridge, IG, gunite, USQ 1152 1.5 hp motor (3450 rpm), Pentair Pinnacle Pump
    Jul 2011
    Southern California
    15
    About how much does it cost to make one?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What is the longest dimension of the pool?
