Results 1 to 16 of 16
Thread: Taylor Speedstir
    Brisbane , Australia
    54
    Taylor Speedstir
    G'day
    Anyone know if the Taylor speedstir is available in Australia? Can't find it anywhere on Google.
    Thanks
    Brad
    19,000 gallons
    Zodiac Tri Series SWG
    Hayward S310T Sand Filter
    Poolrite SQI 600 pump.
    IG Concrete, quartzon surface
    Built 1997
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: Taylor Speedstir
    Not sure if it is available directly in Australia. If you can't find anywhere to get it you can always buy it from a company elsewhere and have it sent to a freight forwarder to be forwarded on to you.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    There is also the option of building your own, uses a magnet 9v battery and computer fan. Google it and you'll come up with something. I thought about it myself but ended up buying one as it's a nice small package that will fit in the TF100 test kit.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Apparently this place not only has the TF100 but also the speed stir.
    TDCHLORINATORS.COM.au. (In Brisbane, mailorder)
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by msgtdan
    What did you take out? Mine is completely full.
    Sent via Tapatalk...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Toss the blue box for the little taylor kit...at least that's how I got mine in!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    The OTO kit is still in its blue box as I'm still using up my old HTH 6-way. Once that's all gone I'll see about moving bits around, I don't think I need 3 vials which I have now. I will find room for the speed stir!
    Dan D
    30,421
    I managed to get my speedstir in my TF-100 kit, too. You may have to rearrange some of the partitions a bit and I did remove the blue box for the K-1000. I also slide the small 15ml bottles (R-0011L and R-0010) into the clear mixing cylinders.
    It ends up being a "full house" but it can be done.
    22,550
    I also have the SpeedStir in my TF-100. I'll post a pic later of how it's laid out if I can remember to.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I have been meaning to do that as well. I have been too lazy to mess with it.
    54
    TD Chlorinators are out of stock ATM so I'm getting a quote from a reforwarder in the U.S.
    19,000 gallons
    Built 1997
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Finally got the energy to take a photo of my TF-100 organizer /w the Speed Stir in it.
    I removed the Taylor basic kit, added a divider from the ones included with the box. Then organized it as you see below.
    I also managed to stuff some extra DPD re-agent and a syringe in there. The blue things you see to the left of the ST are milk jug caps that I used for hand mixing before I got the ST. These are the older snap on caps that you can just rest on top of the jug, then WHACK! with your hand and it goes down over the threads. Can't do that with the new ones, so these work better I found.
    The image is higher res than the forum will show, but you have to open it manually in a new window/tab.
    22,550
    Since y_not posted his, I guess I'll post mine.
    TF-100 & SpeedStir by Bama Rambler, on Flickr
    I usually keep a second bottle of R-0871 in the lower right corner where the test cylinder is.
    I keep the R-0013 and other things in a Tupperware lunch box.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Oh, of course.... gotta keep up with the Jones' huh?
    So you tucked the CYA test away, all on its own. Banishing it to the far corners of a cabinet, eh? Punishment for the pain it caused you when you used pucks. Am I right? :P
    Did you make this decision to move it externally because you use it less?
    I'd love to have both the Taylor basic & the CYA test in the same box. But alas, there isn't room.
    I have thought about getting another bottle and putting about 14oz of CYA re-agent in there, that way I can have it next to my Taylor basic in the left compartment maybe. But alas, I'd still have to store a big CYA bottle somewhere. Hrrmmm... choices.
    Is that a folded up paper you put under the measuring scoop to facilitate easier removal?
    I find it's perfectly easy to remove when it's right side up. But if it flips upside down, UGH!!
    22,550
    I was one of the lucky ones. I only succumbed to the Frog a little while before finding this place so my CYA never got "off the scale" but, I store the large bottle of R-0013 in the lunch box because I only use it about 3 or 4 times a year and I also store the borate strips and salt test in the lunch box along with a bunch of other stuff (liner scrap, extra vials, another stirrer, extra stir bars, etc).
    The folded paper towel is dual purpose. It provides a cushion making it easier to remove the scoop and it keeps the compartment clear of any powder granules that may be left on the scoop.
    I have thought about repurposing an R-0871 bottle and filling it with R-0013 CYA reagent, but I haven't done it yet.
