Results 1 to 7 of 7
Thread: Cleaned Filters and Pressure Didn't Drop
    I have a Hayward cartridge filter. I just did my first cleaning, the filters were very dirty, lots of sand etc., I cleaned them very well, soaked overnight in TSP, then cleaned/rinsed again, there was piles of sand/debri after cleaning, they were a completely differnt color. My question is, my system was running right at 20psi prior to cleaning, and is still running the same after cleaning. I as expecting a substantial drop after all that. Is there something else I should be doing? The cartridges appear to be very clean now.
    15k freeform shotcrete sport pool 3.5-5-4, hayward swimclear c4030, 1.5hp hayward Northstar pump, polaris 280 with hayward booster, hayward turbo cell swg
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Cleaned Filters and Pressure Didn't Drop
    What was the starting pressure before they got dirty?
    Sent via Tapatalk...
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by jamie1983
    Is the pressure guage good? (It should drop to 0 when the pump is off)
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jul 2012
    CA
    240
    Do you have a spa? for some reason my psi goes up almost 13pounds when i have it on spa mode, freaked me out first time i noticed.
    25k I/G ecostar ccplus Polaris plaster
    I thought it was in the 10-15 range when it was first up and running. The gauge is good, goes to 0. I do not have a spa. It dropped a little 3-4psi when I cleaned...I just expected a more substantial drop. Is 20psi high? Will that hurt the system or is that an ok range.
    38,285
    Your last post and first post seem contradictory. The first says you got no drop in pressure by cleaning and the last says you got 3-4psi drop by cleaning.
    Either way, I think it is typical for the equipment to have a max pressure rating around 50psi ... 20psi is nothing to worry about.
    Sorry prior to cleaning it was around 20..I'd say maybe 23...now after running a few days it seems to have settle around 20. So I've seen a slight drop, but not quite what I was expecting. Glad it's nothing to worry about.
