Results 1 to 10 of 10
Thread: Mesh Safety Cover - How Tight?
    Oct 2010
    Highland, MI
    96
    I have a mesh safety cover contoured to my kidney shaped pool with a set of steps on each end. The PB installed it last year and informed me to get the water level to about 15" before it snows. I did so and got 4 small dime sized holes in the mesh last year. I think this was from some water puddling on top and re-freezing. Other than that seemed ok.
    This year I installed the cover and water is about 24" below right now. The cover clearly stretched a bit this year and is already pretty saggy almost touching the water. It looks like a trampoline when windy! Thoughts? Keep it loose? Tighten the springs up? Add water to 15" again?
    Mike
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Mesh Safety Cover - How Tight?
    Tighten the springs. It should be flat with the deck all the way across when the cover is dry. Seems like mine had a length to compress the springs to. I don't understand how ice could have put holes in it unless it was flapping in the wind.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Ice didn't cause those holes. Holes are mostly from dragging the cover, insects(ants), or rodents. You must adhere to the 15" rule as having the level lower means when the water freezes the weight of the snow load will be solely upon the cover which is what causes damage (and will void warranty). The proper tension is typically 70-75% compression on springs. If it was a brand new cover you would use around 90% compression as the cover will relax a bit after installation. if your cover was solid ultra-loc you only use a 60% compression as the cover doesn't stretch much.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2010
    Highland, MI
    96
    How do you set the compression? Confused? None of the springs are stretched.
    SW Indiana
    9,199
    Quote Originally Posted by mschmidt33
    Generally by tightening the straps before hooking the springs on the anchors
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by JohnT
    I was new to thus this year. Just start with a pair on opposite sides of the pool. Remove one strap on one side and adjust to take out an inch. Reattach and check the other side the same way. As you get the tension right the springs on both sides will be compressed more than halfway. Find another pair... Repeat.
    Sent via Tapatalk...
    Oct 2010
    Highland, MI
    96
    Don't you mean spring stretch vs. compressed? They are already fully compressed when unhooked.
    Quote Originally Posted by UnderWaterVanya
    Dec 2009
    Central Massachusetts
    2,690
    No, he had it right. When tension is put on the cover, the spring compresses instead of being stretched.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Here is a quick example of how springs look.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Oct 2010
    Highland, MI
    96
    Guess I need to go take a look huh... thanks guys. Will tighten it up so its flat and fill water to 15"
