Thread: Pentair check valve
    Dec 2011
    Lake Havasu City, AZ
    48
    Pentair check valve
    Is there only one style pentair 2" check valve?
    It seems that Pentair makes only one check valve for 2" pvc. I looked on their website and they only show one.
    I got a reply back from the company I want to order from and they only carry one style.
    I have the see thru and the valve is sort of egg shaped. The valve is all deteriorating and one the spring is shot. I might as well do them all.
    Just making sure since I need 10 of them.
    Odd that the entire valve assembly is less expensive than the just the valve itself.
    I found these for only $34 and free shipping over $50 so I'm covered there.
    http://www.westsidewholesale.com/pool-s ... 63042.html
    Thanks
    38,242
    Re: Pentair check valve
    Yes they only have one check valve (263042) and the rebuild-kit (263042Z).
    Silly that the full valve can be bought for less $ than just the internals ... that just seems dumb since it is not a matter of number of items run on the production line influencing the cost. Just unscrew what you need and put it into your existing valve to avoid the re-plumbing
    Dec 2011
    48
    Thanks
    Looks like I'll have a bunch of stainless screws leftover too.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Budman
    Thanks
    Never can have enough of those.
    Sent via Tapatalk...
