Just starting my upgrades
Nov 1, 2012
2
Hello everyone, I am new to this fourm but not new to the AG pool. When I first got my new hard side pool I knew I wanted to make it look nice (everyone does) but work and life always seemed to get in the way. Two years ago I started on the deck, but not a ordinary deck, my wife wanted a complete enclosure lip over. So from the first hole to the last pole I did all the work myself. Now that I am done with the deck portion, it is time for me to start running the electrical for the light post at the corners, electrical outlets and pool electrical. My total plan is to build a wet bar and hard plumb the pool. All electrical will be controlled from the back of the bar. I will install a weatherized projector at the back of the deck that will be on lift servos that way when not in use it will be a deck. The screen will be motorized to drop down between the second story windows. I know all this sounds daughting but believe me the deck was the hard part. I will provide photos as I go along if anyone is interested. Here are photo of everything so far.[attachment=2:i87m0wr6]IMG-20121101-00059.jpg[/attachment:i87m0wr6]Photo showing the deck overall[attachment=1:i87m0wr6]IMG-20121101-00060.jpg[/attachment:i87m0wr6]The counter sunk traps to get to the Skimmer and pump.[attachment=0:i87m0wr6]IMG-20121101-00062.jpg[/attachment:i87m0wr6] The pump under the deck.
Phil
As you can see from the photo, the deck is pretty high about, it is almost as tall as the next door fence line. So what I plan on doing is building privacy corners, to say each corner of the deck will have about a 6' high fence that extends from each corner about 6' to 8' then we will put railing between the remainder so we can see what is going on in our yard. That keeps the looky loos out because sight line between all the houses are about at the corners. Then I will mount gas lamp like light post in each corner.
