Thread: ONE NIGHT BELOW 32 THEN CLOSE
    I'm planning on closing my pool friday.The water temp. is now 58 degrees. Tonight is forcast to 28 degrees then a warm up to the 50's tomorrow. Will my pump be alright turned off one night at below freezing temp?? Thanks.this is my first year keeping it open this late.
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    38,274
    Re: ONE NIGHT BELOW 32 THEN CLOSE
    It takes a significant amount of time below freezing before you will have a freezing problem ... although a lot of wind can speed things up.
    Being slightly below 32 degrees for a few hours is not likely a problem.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Yeah you'll be fine.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,085
    Toss a blanket or jacket over it if you're very worried. Although it takes a lot to run into a problem. I had one running this year in mid-April with temps in the 40's with no problems.
    4knights's Avatar
    NE Kansas
    419
    My water temp is 43 and we had 2 nights of 24/27degress last weekend. My system has freeze protection so the pump just stayed running. No issues at all. I did throw a wool blanket over the filter just in case. Doing final cleaning after pouring the concrete then will do final winterization this next week.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Thanks fellas,,just wanted to be sure-- I did throw blanket over pump but I dont think it was needed. Planning on closing tomorrow,water temp is 56 degrees. Longer than I have left it open before but I hope it (and an early opening) will make things easier come next season.
