Results 1 to 7 of 7
Thread: Winterizing inground pool - equipment below water surface
    Feb 2012
    Winston Salem NC
    161
    After an easy first pool season, I am not preparing to winterize. I should have my safety cover ordered by the end of the day tomorrow (custom fit due to the 4' radius corners on my 18x36 rectangular vinyl pool), but looking for any tips for winterizing.
    Our equipment is located a good distance away from the pool, under my shelter on the back of the detached garage. The location of the equipment puts it below the surface of the water (even at its "winterizing level").
    For the skimmer lines (2), I believe it is as simple as blowing (or vacuuming) the water from the lines once the water level is lowered. What about the main drain line? I have 2 main drains that tie into one line near the edge of the pool. Is there a good method to get the water out of them? Am I left to simply wrapping the exposed pipe at the equipment pad with insulation? I am in central NC, so we do not have brutal winters, but you never know.
    Thanks for all help!
    Mike
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Winterizing inground pool - equipment below water surfac
    You are supposed to winterize a maindrain by blowing air from the equipment pad to the maindrain on the bottom of the pool until air starts to bubble out and then you trap the air in the line by shutting off a valve or quickly plugging the line
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Feb 2012
    Winston Salem NC
    161
    Thanks
    I had not thought of that.
    Tigershark QC Robot
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Another option that MAY work and it's what I plan to do but haven't yet due to water temp - is to use the Gizzmo type device in a skimmer and have only that skimmer and the main drain(s) connected by setting the filter to closed - as you blow into the skimmer - the outflow should be via the main drains if you are lucky. If not then blow from the pad side if you have an option to do so.
    Feb 2012
    Winston Salem NC
    161
    X-pertpool
    What is normally used to blow through the main drain?
    I have a commercial grade backpack blower, but something tells me that is not what is normally used.
    Thanks
    Tigershark QC Robot
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by head gamez
    X-pertpool
    Thanks
    Some use shop vac, some use compressors, some use blowers, some use dedicated machines.
    Sent via Tapatalk...
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I use a cyclone liner vac (google that). But that's like $400 for only one purpose. An air compressor will work and you might already own one or know someone to borrow one. It doesn't take too much PSI, compressors are just slow as the total volume of air is relatively low. Technically you can use a blow through compression plug and a bicycle pump.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
