Thread: High chlorine but still have algae
    The chlorine in my pool is at 4.0 ppm, yet I recently noticed green algae on the wall of my plaster pool. Why would this happen?
    38,415
    Re: High chlorine but still have algae
    What is your CYA level? For that matter, post up a full set of test results.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    4ppm is not high chlorine.
    If your CYA level is really high, you need more chlorine to combat algae. That may be your problem. Some forms of powdered chlorine will increase your CYA level. I just recently experienced this when switching from liquid chlorine to powdered chlorine based on a pool store recommendation I should've known not to take their advice; luckily I caught it relatively early.
