Thread: How often to pump water off winter cover?
    Jul 2012
    Chicago, IL
    358
    How frequently do you all do this? I closed a couple of weeks ago and have pumped (well siphoned actually) off water twice. My concern being that as rain accumulates it adds more and more weight to the cover, and will continue to push water up the walls or eventually tear the cover. I did leave a fair amount of slack to allow for this to some degree, but not sure if I am being overly paranoid. Do I have more of a safety margin than I suspect?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    22,553
    Re: How often to pump water off winter cover?
    I pump (or siphon) it off whenever it gets a good bit on it. It'll stand a lot more than you think it will.
    May 2012
    Montville NJ
    545
    IF your cover is laying on the pool water - as it should be - then is it not holding much weight. If you were to try and pick it up off of the pool, then it would be under a lot of tension.
    I siphon mine off whenever there is water on it, so that any leaves that get on it blow off.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    I just got a leaf net this year
    I also decided to try using a pillow, which so far seems to help. Water is only on about 1/3 of the cover, 5" deep. I will siphon a good amount of it off soon since the leaves are about done falling.
    The previous two winters without a leaf net or pillow, I didn't siphon any off until spring. The leaf gunk was a HUGE mess.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    X-PertPool's Avatar
    Exeter, PA
    1,385
    you can keep the cover dry if you'd like with a pump or siphon. If you are in an area that has lots of wind it may benefit you to have an inch of water on the cover to help stop it from parachuting.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
