Results 1 to 14 of 14
Thread: Newbie - Test kit question
    Oct 2012
    Katy, TX
    35
    First, thanks for all the time and energy you guys have put into this site. I've read for hours, learned many lessons, and and now transitioning to the BBB method since after 1 season (brand new 1st time pool owner) I've already had CYA->algae problems. My question is - I have the DPD test kit from Leslie's which seems like a pretty good kit, but the range is 0-5ppm, which supplemental kit should I buy? I'd like to be able to test shock levels (even though I should hardy if ever need to shock) accurately, and track whether I'm losing chlorine overnight in shock situations.
    Is something like this what I need? http://www.hach.com/product.detail-over ... 7640219528 Anyone else have any suggestions for just a more sensitive DPD portion of a test kit?
    Also, here are my numbers from testing: https://docs.google.com/spreadsheet/ccc ... CNkE#gid=0
    Paul
    15,000 gallon colored plaster in-ground with spa-spillover
    Hayward Tristar 2-speed 1.5hp main, Hayward Tristar 1 speed 1hp water feature
    Hayward Cartridge Filter C4030 & Tiger Shark
    Hayward ProLogic Automation & Hayward 400k BTU Heater
    Stenner 45MPHP10 Peristaltic Pump
    38,237
    Re: Newbie - Test kit question
    Welcome to TFP!
    Does your kit already have the CYA, CH, TA tests?
    You certainly need to add the FAS-DPD chlorine test which allows getting the high FC and CC levels. You can find all the single tests and refills at tftestkits.net
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Oct 2012
    Katy, TX
    35
    Yes, I have the Leslie's Kit that is one of the recommended kits - http://www.lesliespool.com/Home/Pool-Ch ... 81329.html but again, its range is 0-5ppm. So I'm looking to supplement this kit with just a better FC test kit, not a completely new kit.
    I also previously posted a link to a spreadsheet with my test results, including CYA, TA, PH, FC, CC.
    Paul
    38,237
    I did not look at the link on my phone.
    If you got one if the recommended test kits, it would have included the FAS-DPD chlorine test. Likely you bought the 2005 and not the 2006 ... rebranded by Leslie's. You have to order the FAS-DPD test and kits as most pool stores do not carry them. You can get the FAS-DPD test alone from tftestkits.net
    Oct 2012
    Katy, TX
    35
    Thanks Jason. So the Taylor Taylor K-1515-C would be a good equivalent then?
    38,237
    That number sounds familiar. There is only one FAS-DPD test so if that is it then that is what you need .
    I think tftestkits.net provides more reagents than other sites.
    Oct 2012
    Katy, TX
    35
    No problem, I realize that working on a phone is a bit difficult! Anyway, they have 2, the K-1515-C (2oz reagents) and the K-1515-A (.75oz). Not sure how many tests that will give me, but for $50 it should last a whole season I think.
    38,237
    I think the C size is less than $30 on tftestkits.net
    The owner of that site it's the same owner as this forum ... and generally have good prices and very fast shipping.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    This is far cheaper than the "Taylor branded" kit you're looking at. It contains the same re-agents, made from bulk Taylor bottles, just different packaging.
    http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Oct 2012
    Katy, TX
    35
    Ordered it, thanks!
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by houstonTex
    Ordered it, thanks!
    *Sylvester Stalone voice* Sure thing boss!
    You'll love it. The right tools make the job soooo much easier.
    Did you get a speed stir?
    Oct 2012
    Katy, TX
    35
    No speed stir yet, but I'm sure I'll cave at some point soon
    22,539
    You can believe that once you get one you'll wonder how in the world you ever did without it.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I second that.
    HoustonTex,
    We'll turn you into a bonafide pool nerd before long.
