Results 1 to 17 of 17
Thread: New plaster problems
    Oct 2012
    Orange, CA 92866
    15
    Hello everybody. First time here and I have already found so much info that I needed. Great forum.
    I am in Southern California and had our pool re plastered in June. That is when my nightmares started.
    The pool is gunite pool (not sure how old, guessing 30 yrs or so ? based on old brass pump that was there before I replaced it)
    28000 gal with attached spa. around 40x25, 9 ft on deep end.
    New Pentair variable speed pump
    DE 60 SF filter
    I would like your opinion about the finish. As for the pool many stains and color variations. The co. that did the plaster
    blamed me for staining my pool by not having properly balanced water, not brushing when starting up.
    I tested the water daily and once a week had it tested in the pol store.
    The pH was right around 7.6 never any higher. TA 90. Calcium hardness around 250. TDS was 600
    I brushed the pool min three times a day.
    They did agree to do an acid start up (14 gal of acid in the pool and then added 2 more gal after 4 days)
    The pool looks better, but still has spots mostly at the bowl. I guess they may go away after some time and expose more aggregate ?
    The finish is California Quartz - Malibu Is anyone familiar with it or has pictures of their pool with same finish so I could compare ?
    Also is there ultimate sealant to seal stainless steel light niche in spa that was damaged when old plaster was removed ?
    I have used A+B before on the skimmer and it is holding well for last 7 years. I did not try it on stainless steel which is in the spa and will be exposed to hot water.
    Any input and/or opinion would be great.
    Thanks.
    [attachment=2:t7cgr7gd]spa1.jpg[/attachment:t7cgr7gd]
    [attachment=1:t7cgr7gd]Spa3.jpg[/attachment:t7cgr7gd]
    [attachment=0:t7cgr7gd]spa2.jpg[/attachment:t7cgr7gd]
    S. California
    28K 36x22 gunite IG pool with attached spa, Quartz plaster, Pentair VS pump, DE Pacfab filter, Raypack heater.
    Pool replastered June 2012
    30,432
    Re: New plaster problems
    Welcome to the forum. I am not sure what your question is? Do you want an opinion about the calcium scale?
    Oct 2012
    Orange, CA 92866
    15
    Hi Dave, I am trying to get opinion if the finish look like it has calcium stains or not so good finish job troweling
    As someone told me, to them it it looks like workmanship issues and possibly wrong ingredients used in plaster
    So i am looking for more opinions before I spend money and hire NPC to have them come out
    Can the plaster be tested in a lab ?
    Thank you.
    S. California
    30,432
    If acid removes it, then it is likely calcium for sure. That said, I suppose there could be something in the mix that produces calcium but that seems a stretch.
    It is hard to comment on the workmanship from a few pics so that seems something you and the plasterer need to somehow get on the same page or have someone visually inspect the work.
    Oct 2012
    Orange, CA 92866
    15
    Well, all I know that acid removes many things including hard "cream" of finished concrete, metals, etc
    It will destroy lime stones and other soft materials permanently. So yes calcium would be easy to remove with even mild acid.
    I am no pool expert, but I am a contractor so I work with many different materials.
    I am addressing the uneven areas in the spa (I only took pic of one wall) pit holes, trowel marks, etc. and looking for an expert opinion of others to tell me if this is how plaster look normally when done.
    Should I add more pics ? Would that help ?
    Thank you
    S. California
    I'm not an expert either but I would be ****** if my plaster looked like that. Hopefully you haven't paid them.
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Oct 2012
    Orange, CA 92866
    15
    This is in the spa, so imagine sitting in that.
    I am trying to get them to re plaster the spa, that is after they find and fix a leak in it.
    Will post results.
    S. California
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I agree with Blaine...that looks like a really lousy job from those pictures. I also agree w/ Dave...can we see a larger view? Are the pictures all the same plaster? The picture w/ the air bubbler looks quite different from the others.
    Oct 2012
    Orange, CA 92866
    15
    Quote Originally Posted by Melt In The Sun
    I will take more pictures and post them. yes it is same plaster. All pics are from the spa. The pictures with the air bar are at bottom and that is what the finish suppose to look like with the exposed quartz .
    The two other pictures are from the spa wall and you can see part of the seat in the corner.
    The company did agree to replaster the spa after they finaly found the leak which was at the bottom drain (hole in plaster near suction line according to leak detection company
    now I can only assume that the pool finish is for the most part as bad but it is not so visible because of the depth of water
    thanks all for your inputs
    S. California
    Oct 2012
    Orange, CA 92866
    15
    after call to NPC and even without them coming out, they will replaster the spa.
    S. California
    Oct 2012
    Orange, CA 92866
    15
    Here are some pics
    [attachment=1:16txdbvp]Pool small.jpg[/attachment:16txdbvp]
    [attachment=2:16txdbvp]pool bowl.jpg[/attachment:16txdbvp]
    [attachment=0:16txdbvp]Spa small.jpg[/attachment:16txdbvp]
    S. California
    These recent pictures look good but they are not as close to the plaster as the first ones so it is hard to tell. The trowel marks you are showing in this more recent set of pictures, 2nd picture, are a non-issue, that's just the way it goes. The plaster, however, should be smooth and not rough like you were showing originally. Those first pictures didn't even look like they did any finish troweling.
    Blaine
    My pool build:
    Oct 2012
    Orange, CA 92866
    15
    I think it shows differently in close up in the spa and not through water.
    Anyway let see what the second attempt will look like in the spa after they re plaster. I certainly hope it will be better.
    S. California
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Some underwater pics, closeups of the problem areas in the main pool II think might really help out these wise folks here at TFP.
    If you don't already have an underwater/waterproof camera, consider the following.
    You can get a disposable Fuji underwater 35mm film camera for less than $10.
    Another cheapo option, a Zip-Lock baggie and a cheap point-&-shoot.
    I'd test it with a dry paper towel inside, then go diving in the pool with it. If you come back up and dry off the outside, inspecting the contents within and find it's dry. Then I'd say your safe to put the camera in, just make sure it's fully sealed!!! Maybe double bag it.
    There are also cheap waterproof bags for point-&-shoot cameras for around $20. Neewer has one for about $5 and DicaPac has a better one for around $20. Just look on Amazon, lots of options.
    If you want to spend around $100, you could do one of the following.
    Also, there are many waterproof cameras, good to various depths, on Amazon for pretty cheap.
    There's also the GoPro HD camcorder series that's good to scuba level depths and takes 5MP stills.
    Keep in mind, it wouldn't really just be one use if you didn't go with the disposable. These are a blast, underwater, in water and half water/half horizon shots are super fun and very amazing!!
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Oct 2012
    Orange, CA 92866
    15
    Quote Originally Posted by y_not
    I have small cheap camera , what I don't have is wet suit to go diving
    But will try to get some pics.
    S. California
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Quote Originally Posted by vman1
    Baaahhhh, just hold your breath.
    or have the kids do it, I swear they have gills. LOL
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    If the camera has a self-timer you could rig something on a pole and use a ziplock.
    Sent via Tapatalk...
