Thread: Adjustment of Pool Return Inlet Eye
    Oct 2012
    Houston TX 77064
    101
    Had a gentlemen come to troubleshoot water leak and changed the direction of all the Return Inlet Eyes. My pool is old 80's and I can't find a blow out to see how to re-adjust. Looks like a fitted shell screwed to the pool wall, the gentlemen told me to slightly unscrew the four screws, then put the screwdriver in the eye and seat then turn to adjust. I did this but can't find the point to which the screwdriver is seated into something in the eye, just goes all the way down the throat of the pipe. Any thoughts!
    13200 gal, IG, plaster, built 1985, replastered 2012, Mytilus MA-90C cartridge filter, 2716 Blue Line In-ground Pump and Motor (1 HP), (manual clean/brush/test with Taylor K-2006, TFP since 2012) in Northwest Houston TX
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Adjustment of Pool Return Inlet Eye
    Sounds like you have "swimquip" return fittings. The ring that's held on by the 4 screws holds the adjustable center section in place by friction.
    Loosening the screws should allow you to adjust the movable center section. Either by hand or by using a screwdriver sideways in the center section.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Oct 2012
    Houston TX 77064
    101
    that's it, sat out there and looked at it. It dawned on me (from my childhood pool days at my parents) the screw driver doesn't seat to move, it moves it. Some of them have hoods and are partly blocked (like a 1/2 moon hood and then covered 1/2 moon) - can't get a screwdriver in it, still trying to figure out how to move that one, it's like really stuck. May have to get that gentlemen back to adjust himself, since he started it. Thank you so much for the prompt response.
