Thread: leaks :( anyone heard of flood grouting
    May 2011
    No. CA
    111
    I suspected a leak all summer but did not want to shut down the equipment to find it.
    I used the brain-dead approach and turned everything off, and the leak was 3/4" plus per day until the water level got close to the return jets, and it has since stabilized.
    Next step is a pressure test, but in the mean time I started looking for leak repair companies, and I came across a web site that uses an two part process called flood grouting. ( f l o o d g r o u t i n g . n e t )
    Has anyone heard of this process?
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: leaks :( anyone heard of flood grouting
    Never heard of it, but it sounds neat. Although I don't think anything would compare to actually replacing a bad line with a new one.
    Get quotes from them and from someone else who will dig up the line and compare.
    You can kinda check to see what line is broken yourself. If you cap off one end of the suspected pipe open up the other end and fill it with a garden hose to the brim and then watch to see if the water starts to fall below the brim. I do this after I'm done pressure testing to show the customer as it's a much more visual way of understanding something is wrong as opposed to a pressure gauge dropping.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    May 2011
    No. CA
    111
    Thanks.
    I haven't found a local dealer that is doing the flood grouting.
    Also, I suspect the leak is under concrete which will complicate the "dig up and fix".
    X-PertPool's Avatar
    Exeter, PA
    1,385
    http://www.americanleakdetection.com/ use tools from Anderson www.leaktools.com including listening devices and helium detectors. In other words if a line has a leak you can usually pin point it to within a few feet. The helium detector works by pumping the gas into the line and the very light gas will seep out of the leak and through the concrete deck itself since the molecules are so small.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
