Thread: giving up - how do we remove the hand rail at the steps?
    hi guys. y'all were super helpful a couple of years ago when we were trying to get our (circa 1975) inground pool going.
    unfortunately, just about everything that could go wrong, has, and we are simply giving up on it, gonna cover it up and just ignore it for the time being.
    we never bothered to put the deep-end side ladders back in, but the guys who put in the new liner years ago didn't take out the handrail for the steps.
    i don't know if this sort of handrail is permanently cemented in, or if there's a way to remove it.
    any helpful hints on how to remove a handrail that's probably not been moved since it was originally installed, in the mid 70's? is there a trick to it that i just can't figure out, or should we just rent a cutter from Home Depot and cut it off?
    Inground, Vinyl 18x37 Grecian (probably 23,000?)
    1 HP Pump + Hayward C900 Cartridge Filter
    "rigged" aboveground plumbing.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: giving up - how do we remove the hand rail at the steps?
    Have you tried to just wiggle and pull them free? That's how ours come out, from what I gather having watched it as opposed to having done it myself. Usually, there's just some silicone in there. If they haven't been out a while, spraying some water around the area might help flush any debris around the post.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    ^sorry, I stand corrected. H. Sez there is a bolt u have to loosen first. If it's stuck, some wd40 might help!
    Helpful Links:
    30,419
    Standard configuration has a bolt(s) holding them in. You should loosen that bolt 6-8 turns and then be able to wiggle it to break the bond and then it will lift out. A pic would be helpful if yours is not standard.
    thanks, y'all! i'll do some poking around and if i can't figure it out, i'll post a picture. thanks so much!
    The bolt usually pulls up an anchor wedge. When the bolt is loosened, you usually need to tap on the bolt to push the anchor wedge back down. There might be an escutcheon plate covering the anchor cup and bolt.
    Support the site
