Results 1 to 13 of 13
Thread: Vacumming/Brushing the pool
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Just wondering how often other AGP owners vaccum and brush the pool? I am thinking once a week for brushing and I shouldn't have to vaccum unless the polaris doesn't do a good job.
    Also, since I don't have a deck around the pool. It's going to be a bit challenging to do it from the outside. I guess I'll be going in to do it.
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mar 2007
    Texas
    444
    I vacuum mine about once a week, if it needs it or not 8) . I have a deck but I still get in the pool to vacuum (just easier I think), I use any excuse to get in the pool
    27' Round AG, 17,200 gallons, sand filter
    Guest
    Pools are llke teeth. None of us really brush either of them enough!
    Mar 2008
    Evans, GA
    323
    Well, since hubby is off Sunday and Monday's guess what he's going to be learning?
    *~ Laura ~*
    TF-100 Test Kit
    Quote Originally Posted by waterbear
    Wearing your 'Dentist Hat' today, I see!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Jun 2007
    MA
    165
    Last year I did it every other day while in the pool. Sometimes just to get some time alone in the pool I would do it even if it didn't need to be done.
    Cheryl
    14X42 Intex Ultra Frame
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    I did it a few times a week, more if needed, less if we stayed covered more.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Casey's Avatar
    SW PA
    10,433
    I usually vac and brush once a week.
    I've been slacking though because it's been cold here.
    Aug 2007
    Pensacola
    129
    If you take care of the chemicals, you shouldn't have to brush much at all. vacuuming will depend of course on the amount of tree trash, etc that may be nearby. I have trees on 3 sides of my pool and usually have to vacuum a couple times a week(unless the wind is blowing out of the E or SE all week and then I can go without having to vacuum at all). It all just depends on your situation, but in reality, it isnt gonna be much of a big deal at all.
    24' AGP vinyl, 3/4hp Pentair 2-speed, Pentair Quad DE 60
    Pool Rover Jr.
    TF-100
    Jul 2007
    New Hudson, MI
    48
    Last year was our first with a permanent pool (had an Intex the year prior). We never brushed at all last year. On opening this spring, however, the need to brush was evident! I doubt we'll brush very often now that we're up and clean again though.
    I think keeping the water balanced helps with the need for brushing, but you will want to vacuum somewhere around once a week, depending on usage, weather, etc.
    Scott
    27'x52" AG Vogue Impact, Waterway Cyclone 200 cartridge filter, Waterway pump w/2 HP 2-sp motor, 8mil solar cover, Raypak 206 nat gas heater, Pool Rover Jr.
    Jun 2007
    MA
    165
    I usually vacum daily the kids get so much **** in their we don't have a deck they use a water bucket to srep in before the ladder.
    Cheryl
    Mar 2008
    Evans, GA
    323
    Re:
    Quote Originally Posted by my4boys2002
    We got to do this too. I have another solution too. Is to keep a small bucket (I used one of the kids) on the pool rail or in the pool and since I am usually in there. I use that bucket to make sure there is NOTHING on their feet. The area behind the pool steps has A LOT of sand already. My p/65 STINKS! I am already looking for a new automatic pool cleaner to replace it.
    *~ Laura ~*
    TF-100 Test Kit
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Re: Vacumming/Brushing the pool
    This is probably my biggest problem that I have had since starting BBB.
    The water is so crystal clear I can see every little speck on the floor
    Then I'm vacuuming every other day, sometimes I have to get in the pool just to get every spot, it may take hours before I'm satisfied... 8) 8)
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
