Results 1 to 7 of 7
Thread: Need Help Again
    Need Help Again
    Hello Forum!
    Ive been away for a while and my 24' above ground pool was neglected in my absence. The water is a light murky green and I was wondering what I need to do to get it back in shape. I was planning on getting it crystal clear again and keeping it that way all winter. I live in Mississippi so the winter will not be that bad. What steps should I take to get it back in shape? I plan to go buy whatever I need tomorrow and fix it up. I used the BBB method all summer and it stayed perfect.
    THanks
    Sharkline Dolphin AGP 24" x 54" Millennium cartridge filter Millennium 2-way 2HP-3/4HP pump
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Need Help Again
    Pool school rocks.... pool-school/defeating_algae
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    38,284
    Re: Need Help Again
    Do you already have one of the recommended test kits? If not, ordering one is your first step. This also means that you will need to wait for the kit to arrive before you can true perform the Shock Process correctly.
    Re: Need Help Again
    I do have the recommended kit.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Need Help Again
    What steps? Post here, read pool school, test, buy and use lots of chlorine.
    - Sent using Tapatalk
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: Need Help Again
    Make sure you stick with bleach or liquid chlorine.
    Use the following formula to compare bleach/liquid CL cost for what you're getting in FC yield per bottle for your money.
    Oz. X percentage in decimal form (ie. 0.825). Then divide the cost per jug by that number.
    So $2.69 - 182oz @ 8.25% would be right around 18c/CL oz.
    Be sure you don't buy powdered chlorine, it either adds unnecessary amounts of CYA to your water, or calcium in the case of cal-hypo.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
