Thread: Freezing Temps & Pool Heater
    Hi;
    We're expecting temps in the 20s overnight and I want to protect the new pool heater from any possible damage. Obviously, I could leave it on but I would prefer to leave it off. The heater is drained and by-passed for now.
    Should I try to blow any excess water out and/or add some pool anti-freeze to the heater?
    Thanks for any suggestions,
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    Re: Freezing Temps & Pool Heater
    Do you have a drain plug at the bottom of your heater? If so, remove the plug to make sure the heater is drained of water. Your heater will be fine if the water is removed.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    OK, thanks for responding!!
    On this heater there are two drain plugs, one on the inlet/outlet and another on the return header. Both have been drained so should be good to go.
    Better safe than sorry is the motto of the day.
    Best regards,
    Gary R.
