Thread: best way for a cover
    Jul 2012
    Richmond, Va.
    43
    Is there a better way for a pool cover in winter?
    Had an AG pool 18 ft for about 20 years. Have a nice deck built around it and in the ground about 2 ft.
    Rare freezing is a problem here.
    Have tried a few things but this is what I do to winterized.
    Drain pump and filter. Disconnect lines and cap.
    Put one of those plastic air bottles in skimmer for expansion against what little ice if any.
    Then use an AG pool cover screwed to the deck with stainless fender washers and screws.
    Then a plastic milk crate (do get a few leaves, keeps away from pump) on the cover with a small pump in the crate. Plugged into an outlet that controlled by a 60-timer switch thatís by my back door.
    Does not work bad. But of course rainwater on cover will push down and cause some pool water to over flow the skimmer.
    So have to add a little water about once a month to make up for this.
    Any better way. Or I have never tried an in ground cover that does not touch the water. And has those spring attachments. Rainwater would just run out my disconnected skimmer hose.
    I know I would pay for this, but getting older and few health problems looking to make things as easy as possible.
    Is this a good idea?
    Best place online to order one?
    Thanks for any suggestions
    6014 gallons aprx
    cartridge type filter
    summer escapes pool above ground metal frame
    SFS1000 SkimmerPlus filter pump with GFCI=1,500 GPH
    install date: 6-1-12
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: best way for a cover
    If you have regular wood deck you should be okay with anchors designed for wood. If you have trex decking or similiar it's not usually strong enough for a safety cover. I like the loop-loc brand but you'll have to call around locally to have one installed unless you were going to attempt it yourself and buy online (stock covers only)
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
