Thread: Valves on skimmers and drains?
    I specified that all drains and skimmers should have valves at the pad. My PB did not follow this when they did it. They put a 3 way between the two skimmers and then T'ed into the drain line directly (no valve on drain line) then to the pump. So, it appears that I have no way of turning off the skimmers (if I ever want to drain the pool) and I have no way to airlock the drain line after blowing it out.
    So, did they just make my winterizing much more difficult? Do I now need to go under water in the deep end, remove the drain covers and plug each line after blowing out?
    Are valves usually installed on each drain and skimmer line or is my request overkill and it is fine the way it is?
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Valves on skimmers and drains?
    Most 3 way valves can be rotated to an off position. So the skimmers are fine.
    Without a main drain valve I'd say you have a bit of a tougher time.
    - Sent using Tapatalk
    38,524
    Although you may have to modify the 3 way valve to allow it to turn. Most have stops that you will have to cut off to allow the valve to turn 360 degrees.
    You certainly want to put a valve on the floor drain pipe to allow you to reduce the flow. That is certainly not the way I would have plumbed it ... makes no sense to me.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2007
    New Jersey
    653
    My skimmers are that way and it's fine. If it's a Jandy type, just point the handle away from the line toward the pump and both are off.
    But you definitely need a valve on the main drain. You can use a rubber plug with an air fitting to winterize, or just try to plug it really fast with a solid plug, but the valve is better and I certainly prefer to throttle back the main drain for better skimming action. You also could not vacuum unless there is a separate line for that.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
