Thread: Stuck Eyeballs
    Oct 2012
    91
    Stuck Eyeballs
    One of the more minor issues I've run into with my short-sale pool is that the eyeballs are frozen in place. I can't move either the eyeball or the ring by hand pressure alone. Is it safe to grab the ring with a pair of channel locks or something similar, or is there something else I should try first? I don't want to take a chance on breaking something off in the wall, so I figured it was wiser to ask before instead of after.
    14,500 gallons, Clean and Clear 150 cartridge, IG, gunite, USQ 1152 1.5 hp motor (3450 rpm), Pentair Pinnacle Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Stuck Eyeballs
    Use a strap wrench first.
    Oct 2012
    91
    Re: Stuck Eyeballs
    Good idea to keep from damaging the plastic, thanks! I was going to pad the channel-locks with rags. I should get a strap wrench anyway, they can be handy.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Stuck Eyeballs
    Use whatever to get the ring to move but there is a good chance there will be a part still stuck in the wall, There is an official tool. SP-1419-T. It fits into the slot and then you turn it like a key. The slot is exactly 1.5" so I've made my own tool over the years with a modified 1.5" dull wood chisel.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2012
    91
    Re: Stuck Eyeballs
    Thanks, Kevin. I'm hopeful that all I'm going to do is take the eyeball out and clean it, just so it's loose enough to move. Nothing will budge now. I don't think I'll have to replace them or any of the piping.
    Feb 2008
    Denton, TX
    5,061
    Re: Stuck Eyeballs
    Strap wrench works, but I have used channel locks before CAREFULLY and with good results.
