Results 1 to 7 of 7
Thread: Temporary large opening mesh leaf cover just for temp use
    I have seen somewhere (over an outdoor fish pond with waterfall), a large opening (maybe 1/2 to 3/4 inch openings) maybe 25% the opening size of "chicken wire" which is usually made with an "octagonal" opening shape.
    I want it very light say 2 to 3 lbs for a 14 feet by 30 feet size coverage. I want to be able to manually flip off, or leaf blow off any leaves that fall on it.
    Typical pool leaf covers are very closed mesh, water permeable but not large particle permeable. They are very heavy and are meant to go on top of a solid permanent solid cover.
    Any ideas?
    Relocated to equipment related forum. 257WbyMag - Forum Moderator
    Re: Temporary large opening mesh leaf cover just for temp us
    Gee what's happening when I have to answer my own post???
    Guess everyone has gone into pool hibernation for the winter. Or I put my question into too obscure a category!!!
    Anyway here is a link to what I wanted http://www.amazon.com/gp/product/B000FN ... 2972638011
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Just so you don't think you are babbling in an empty forum: thanks for the link.
    - Sent using Tapatalk
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Mike, I missed your post but thanks for that link. I was looking for the same thing but didn't realize it!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2012
    Mint Hill, NC
    2,589
    ? The link you provided shows a 3/8" opening mesh - how tight are the normal covers?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If I had to guess, mine is 1/4" and not heavy at all, even when wet, but it's only a 24ft round pool. But that just my opinion. Wet leaves are far more trouble trying to get off than the actual cover.
    From what I can infer from the pictures I've seen what the 'pool care suppliers" for around $100 or more have spacing of , only my guess, maybe 0.3 to 0.5 mm. They let water pass through them but catch from sinking into the water any size of leaf. But they sit on the water and are impractical to be "flipped up" or simple " tightly stretched across" so they don't touch the water. Whether it will be practical to use a leaf blower to blow the leaves off the 3/8" mesh cover that I have ordered, before they get wet by rain, I will let you know, shortly.
