Thread: A new bleach concentration on the market
    Mar 2009
    Charlotte, NC
    539
    My local store’s generic brand of bleach has just come out with a concentration that does not seem to be in the pool calculator.
    The bottle reads: 8.25%, 7.8% available chlorine
    Down on the bottom of the pool calculator under the section “Effects of adding chemicals”, it has a variety of bleach concentrations but not this 8.25%.
    I do see at the top of the pool calculator where you are putting in your target etc. that you can indeed change the concentration.
    Just wanted to let everyone know about this new concentration, and also that is going for the same price around here as the 6%.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: A new bleach concentration on the market
    viewtopic.php?t=51968
    Several threads on this search for "new bleach" if the above is not enough info.
    - Sent using Tapatalk
