Thread: What happens to pH over the winter?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    What does the pH tend to do when the pool is closed? Does it go up or down in a reliable trend?
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: What happens to pH over the winter?
    It should stay mostly the same though may raise a little bit. It won't drop unless there is a source of something acidic to drop it.
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by Christian
    Thanks - I asked because I was looking at CSI numbers and trying to determine what mine would look like over the winter as temps drop etc.
    My current numbers:
    FC 12
    pH 7.8 (measured even though above 10 - I've had pretty good luck with a quickly read test - but I will not take action until I'm below FC 10 just to be sure)
    TA 70
    CH 260
    CYA 50-55
    Salt Unknown but > 0 (none added except via Chlorine)
    Borates unknown (none added by me ever)
    water at 70 degrees
    Vinyl In ground pool
    Assuming Salt is 500ppm for the heck of it:
    CSI: negative 0.05
    (so far so good... even with Salt at 0ppm this is a -0.02)
    With water temp down around say 50 degrees and chlorine down to 3 this drops to -0.24, and if I drop the pH to 7.2 the CSI index is now an aggressive -0.8! With Vinyl this may not matter, but I'd like to know before dropping pH that far.
    Jun 2012
    Mint Hill, NC
    2,589
    This post may answer my question indirectly...
