Thread: Help. Whats this stuff?(video)
    Jul 2012
    CA
    240
    Only shows up when filter is on, cant see any when off.
    Have useed spa a couple times since i replaced water about 1 month ago.+new filter
    ph7.4
    cl 5.0
    ta 90
    ch is low, so is fill water at 4 drops till change, added spa ch up.
    cya 30
    [youtube:3l0egib2]Wpv7jWw47Bo[/youtube:3l0egib2]
    25k I/G ecostar ccplus Polaris plaster
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: Help. Whats this stuff?(video)
    My 1st thought when seeing that film is that it's from your chlorinating tablets in your floater, which the pump stirs up and makes that scum on the water surface through aeration.
    To me it definitely appears chemical in nature, not organic.
    What are you using in your floater?
    Also what is your CH at as well as your water temp?
    When did you start seeing this problem?
    Just for grins, do you have any CCs?
    What prompted the drain and fill?
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Jul 2012
    CA
    240
    What are you using in your floater? spa cl tabs
    Also what is your CH at as well as your water temp? 40ppm around 80-90 no heater except for once.
    When did you start seeing this problem? when filter is on.
    Just for grins, do you have any CCs? havnt checked.
    New house, just wanted to have a fresh start.
    Could it just be turbulence?
    hey thanks
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Marty - do you have a test kit that measures CC's? A FAS-DPD test is needed.
    - Sent using Tapatalk
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Marty,
    What brand and type of spa CL tabs are they?
    IE what do they say on the label?
    EDIT: Also, how are you performing the TA & CH test, as well as what does your fill water test at straight from the hose?
    thx
    EDIT:
    Question for mods and spa experts.
    I'm getting a CSI of -87 to -78 at a temp of 80-90f /w his spa numbers.
    I know as the temp goes up, so does CSI towards positive.
    Doesn't he need a higher TA /w CH that low, or else raise CH since TA is already up at a pretty good number?
    But I see that TA would have to be a rather insane number /w CH that low, so I would think it'd be wiser to bring CH up, but how far in order to compensate for heater use?
    Mar 2007
    San Rafael, CA USA
    12,082
    The spa looks like it's acrylic and the tile pattern painted and not real tile with grout. Without any plaster or grout, there is no need to have the saturation index near zero. Calcium carbonate saturation is needed to protect plaster or grout surfaces. It is not needed for heaters. Metal corrosion occurs from low pH and high oxidizer (dissolved oxygen and active chlorine) levels, not from a low calcium carbonate saturation. My fill water going through copper piping has a saturation index of -0.7 and though it has phosphates for corrosion control, that's primarily due to the monochloramine (used to be chlorine) which isn't moderated in its strength. In a spa with CYA, the active chlorine level is lower than in tap water.
