Thread: Aqua rite display
    Jul 2010
    Longwood, FL
    151
    Aqua rite display
    I pressed diagnostic button after I clean the CELL
    The first display used to be 3300 for salt , now it shows as 3.30 , dont have clue how to reset it back
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Re: Aqua rite display
    Does your water temp on the Aqua Rite now indicate degrees "C" vs degrees "F"? If so you are in the metric display mode. Do this to get out of metric:
    1. Slide the Main Switch to the "Auto" position.
    2. Push the Diagnostic button repeatedly until "F" appears on the display.
    3. Slide the Main Switch from "Auto" to "Super Chlorinate" and back to "Auto".
    4. Push the Diagnostic button to exit.
    Here's a link to the Aqua Rite manual from Hayward.
    http://www.hayward-pool.com/pdf/manuals/AquaRiteAQR.pdf
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
    Jul 2010
    Longwood, FL
    151
    I dont see the "0F" display on my LCD
    Mike_W's Avatar
    Aug 2011
    142
    The display nominally shows salt concentration. If you push the diagnostic button once, it will indicate water temp (it must be on and generating). It doesn't show the units, degrees C or F. If your water temp in Florida is, say somewhere between 60 and 80, it is F. If it is 28 or less, either you are in north Alberta or it is displaying in degrees C.
    Mike
    Jul 2010
    Longwood, FL
    151
    Mike , will try out today. Thanks
