Thread: Hard vs Flexible PVC
    May 2012
    Danville, IN
    21
    I did some searching, but really didn't find an answer to my question. I'm trying to find out how well flexible PVC really stands up over time. When closing my pool this year, I ended up cracking one of the fittings on my suction line from the main drain and skimmers in my IG pool. I'm going to have to redo the plumbing to the pump and probably from pump to filter. I'm considering using some form of flexible PVC for both suction and pump to filter lines, which would make lining things back up easier and isolate any pump vibrations. My concern of course is how reliable the flexible PVC is over time, because I don't want a rupture.
    Are there any recommendations whether to use solid over flexible PVC? Also, what type of flexible PVC is best to use and should it be clamped or glued?
    Also, I'd really like to do something with my discharge line. I have a 4" solid corrugated pipe nearby in which our downspouts used to drain. Any reason I couldn't run the discharge pipe into that drainage pipe? Thanks for your input!
    25K gal IG Vinyl Ell shaped pool, Pentair SuperFlo 1.5HP single speed pump,
    Pentair SandDollar sand filter (Zeobrite), Pentai Intellichlor IC40 Chlorine Generator
    dmanb2b's Avatar
    Apr 2009
    NY
    3,731
    Re: Hard vs Flexible PVC
    Most builders prefer hard pipe...flex PVC is convenient ( I use it on my AGP) and can be used, but tends to break down quicker and is susceptible to termite damage
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    This site has pretty good info - despite the obvious potential for bias they seem to track other people's caveats for using this product:
    http://flexpvc.com/application-guidelines.shtml
