Results 1 to 9 of 9
Thread: Liner Needs Replaced... What To Do for Winter
    Oct 2012
    Central West Virginia
    4
    I'll post pictures tomorrow. It started with one repairable hole above the water line and now we've got a second that is not a tear but more of a crack going down into the water line. The important stuff is in bold, the rest is background to how we got here.
    Starting at the beginning... we bought this house with the pool, which is a 27' round. I did some research and determined it to be a Home and Roam Leisure Pool (now defunct company). The pool was in atrocious shape, and was more of a black swamp with 3 years of leaves in it (a solid 2 feet of leaves in the bottom of the pool)... two ripped covers on top of each other... hundreds of tadpoles and mosquitos. Within 2 weeks, it was cloudy and within another week it was clear. We were swimming within the month. (It amazed me what some chlorine and proper pH could do). A heck of an introduction to pools but at least we got to swim in it for about a month before the weather turned too cold. Closed it properly last winter and was able to enjoy a crystal clear pool this spring and a decent swimming season after we cut down the offending tree over top of the pool.
    I had to leave for a few weeks and being as it is fall, the pool got many leaves in it. Algae has been a problem this year but the liner was so stained I couldn't get all of it off... I was thinking there had to be hidden algae in some places because of having such problems with it. I replaced all the sand in the filter after we finished cleaning the pool last year but in the spring I'll replace the sand again due to the algae problems we've had this year. (PS previous owners said replace it with playground sand. Yeah right, that's gonna do something.... that's what I took out of the filter, too.)
    Anyhow... we had a hail storm 2 days ago. After I finished scooping out the leaves which had blown in during the storm, another rainstorm came up and I had to run inside. The next day when I came out to inspect the liner I found it either lacerated or cracked. I know we should have had the pool winterized already but I am kind of thinking maybe it was a blessing we didn't.
    So my question is what do I need to do for winter? The crack is 2 inches below the current water line, which is draining (on purpose) as I speak, at least to below the crack. Of course we drain it to below the skimmer/fittings for winter. The liner is okay as far as I know below those parts. Should I go ahead and close the pool as usual minus the chemicals since we need to replace the liner? I see no real reason to cover the pool for the winter if we do it this way.
    My concern is if we drain it, that my walls will collapse. There are no parts for this pool and I see that it needs to be above 50 degrees to replace a liner, which I don't really want to get into before winter anyhow... not to mention that I'm afraid of what we'll find when we start tearing things apart. :/ If I find rust, etc then I'm not sure what to do. I had wanted to replace the rails because many of them are dented, but looks like that'll be impossible now due to parts unavailability. Replacing the entire pool is not an option for us, financially.
    So is draining it down to below the crack a valid option for this winter, or due to weakening of the liner, not a good idea? I was thinking for counterpressure purposes...not to mention the fact that I just bought a brand new winter cover, air pillows and closing stuff... my pool budget for the year is kind of shot. However, if I need to set about draining and bracing, I'll figure out some way to do it.
    The previous homeowners inherited the house from a (deceased) parent and weren't able to tell us much about the pool. She thought the liner may have been original to the pool. I did some digging and kind of think the pool was installed around 1992-1993, so I'm thinking it's possible the liner may have been replaced once (how could it last 20 years?) although there are several patches on the bottom of the pool and on the sidewalls, placed by previous owners.
    At least we got to enjoy this season of the pool. That being said, this thing is starting to become an albatross. I know it's blasphemous but if there wouldn't be a 27' pit in my deck if I removed it, I think it would be leaving. We didn't get out in it much this year due to my school schedule and my husband's work schedule, but my daughter does enjoy it. I keep thinking how nice it will be for her when she's a bit older, which is what gets me through the maintenance... which is not so bad when it's not pouring rain and screwing up my pH and chlorine levels. If we can get this liner change under our belts and change out the sand again, it should be a while till we need to do any more serious repair/replacement work. I'm hoping as long as the fresh water gets a good start, it will stay stable.
    Thanks for reading, sorry for the book.
    Home and Roam 48" waterline 27' Round Above Ground Pool (acquired when we bought our house - pool is in the middle of a large deck
    Gallons approx. 15,054
    Hayward 100lb sand filter - sand replaced end of last season (2011)
    Hayward pump
    All seals and gaskets for pump and filter replaced this year
    Oct 2012
    4
    Re: Liner Needs Replaced... What To Do for Winter
    What we started with
    This summer:
    I'll get pictures of the tear/laceration in sunlight tomorrow. Just wanted to show a bit of the "journey"
    Hayward pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    That is a very nice pool and deck! Another plain, overlap liner should not be too expensive. I would drain below the crack and maybe "patch" it with duct tape, then cover and close the pool. In the spring you can replace the liner and be good to go. The sand may not need to be replaced.
    Love TFP? Become a
    TFP Supporter!
    22,543
    Welcome to TFP.
    Even though you're going to replace the liner next year I'd go ahead and close it like you should. All you have to do is raise the FC and cover it. There are no special chemicals required.
    If the tear isn't much below your normal closing level I'd just lower it that far and cover it. You'll still need to drain, blow, antifreeze like oyu normally do.
    Since you replaced the sand I wouldn't replace it again. Don't worry about algae in it. It doesn't grow where there's no sun and once you get the liner replaced you can backwash it clean.
    Once you get it closed, spend some time this winter reading Pool School and some of the topics here.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Like mentioned, drain below the skimmer & return, tape up tear and cover. I wouldn't leave the winter cover off, too much to clean out in the spring and who knows what would get into it. Save through the winter for a new liner. I doubt you'll find any frame damage that you cannot see from the outside though it may be under the deck. You could crawl under there and do a visual inspection before you buy a new liner.
    You daughter will be getting to the age where she'll want to be in the pool all the time. That lasts well into the teens.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Oct 2012
    4
    Sorry to have left and not came back until today. I thank you all for your advice. We've managed to put back the money for the liner that was going to go to a vacation. We figured we'll be spending more time in the pool than we will on vacation anyhow. I did some reading up and I want a US made liner.
    Thank you all for the information and for the nice compliments. The deck needs stained again. I won't be getting to that until next year. Looking like it will be stain the deck then tear into the liner project. Hopefully in April we'll get some nice days to be able to do it. Today would have been perfect here for replacing the liner... 80*+ Too bad I was stuck inside and didn't have a liner anyhow! (Not that I could do it myself anyways! LOL)
    Here's the rip
    That's the biggest one, and there are several other small ones forming. It rained here again last night so it's draining again right now. That one keeps "running" like a rip in pantyhose. It probably has grown at least 2 inches in a couple of days since I posted this. I'm afraid it's gonna keep running all winter. UGH. I'm really hoping my husband will help me clean it soon. I know I've cleaned at least two oak trees out o it so far and there's a maple still holding onto its leaves and I'm sure they'll figure out a way to get in my pool if I don't get it closed soon. Can't do that myself either... I'm not quite talented enough to cover 27' pool by myself yet. LOL.
    Hayward pump
    22,543
    I'd clean the rip up and put some Gorilla Tape over it. That should stop it from ripping further.
    Oct 2012
    4
    Awesome! Thanks! I'll go get some gorilla tape.
    I can hardly keep up with the cleaning and now I can't filter the water since it is WAY below the strainer. :/ Hopefully my husband has off work a day soon that we can close it.
    Hayward pump
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Patch it up with tape, go a 6 inches past the crack with the tape to help prevent it from traveling. Most vinyl glues temporarily weaken vinyl. So if you do want to use glue use HH-66 glue
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
